Need help from the Duc Brain Trust...
Started by Cher, January 07, 2011, 08:46:26 AM
Cher
I received these parts (stock photo) - plus the spring caps - as an awesome white elephant gift at the Muscrat shindig last month (thanks a.m.)
I was assured their installation would be "easy."  No specific torques to keep in mind, pretty much plug-n-play.  But I'm looking at all this now and have decided anything that involves little springs appearing to be bolted under pressure to a clutch plate part is reason enough for pause...
So before I start flailing tools all over the garage in a tantrum, what's the simplest way to attack this problem.  Please kindly note that I'm not above offering beer in return for mechanical services/expertise  ;D
remove cover
clean (optional) (best way is to put it far away from the house and use compressed air while wearing a filter mask)
unscrew current screws, remove caps, remove springs
reverse
i think those torque to like 5 ft lbs or so.  not much.  i use blue loctite on mine because i am anal.  not red, blue.
if you don't clean as above before removal, then just make sure to knock off any debris before putting the new springs it.
** do you believe in life after love??
caffeinejunkee
#2
+1 to above. I do not use loctite, but the person who had the bike before me did (freakin RED loctite at that!!!)--major PIA to get them off the first time.
I just bottom mine out--never used a torque wrench on them.
RichD
Quote from: caffeinejunkee on January 07, 2011, 08:57:42 AM...I just bottom mine out--never used a torque wrench on them.
That is the trick right there.
The springs will keep the screws from backing out.
If you use more than two fingers on the allen wrench when you bottom them -you're about to make a mistake...   ;)
DFW-MFer!
muskrat
and DO NOT strip them if they are on too tight.  Ask me how I know.......in this case heat it up and use a hammer to tap on the end while you twist (do it carefully).  Hell if I can do this you're certainly qualified.  Get to it.
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Cher
#5
Yep, it took longer to do this post than to install the new parts:
Pieces and parts:
Before, 3:15:
After, 3:40:
Thanks, everyone!  Y'all are the best  [beer]
Lisa
Duc L'Smart
'07 1098s, '06 Paul Smart LE, '99 BMW K1200RS, '73 BMW R75/5, '67 Ducati Monza 250 Bevel Drive, '63 Vespa GS 160
muskrat
2015 MTS 1200
09 Electra Glide
Pinocchio
Looks nice! The Paulimoto ones I have seen would look better behind a closed clutch cover. That one looks very well finished. I have always wondered what the expected gain is from one of those spider retainers vs. conventional spring cups. Does it feel any different to you?
1969 Scrambler (450 “Jupiter”), 2005 MTS 1000DS, 2007 Monster S4RS, 2010 MTS 1200S Touring, 2018 Monster 1200R, 2021 Monster 937+
Cher
Quote from: muskrat on January 07, 2011, 08:26:30 PM
your oil is low  ;)
The bike is on it's rediculously angled kick stand - the last picture was taken on a rear stand.  Sight glass has nuttin' but Motul  8)
Quote from: Pinocchio on January 07, 2011, 10:13:09 PM
I'm not sure if there is any performance gain.  It does look cool though  [laugh]  Haven't had a chance for a test ride but I should here in a little while.  Will post up and let you know how the new retainer feels.
muskrat
ah, from the pic you couldn't tell since the one next to it was on a stand.  no ghost to tip the bike over this time right?
2015 MTS 1200
09 Electra Glide
Cher
fastwin
+1 to above. I just bottom mine out--never used a torque wrench on them.
Me too! [thumbsup] No Loc-tite.
TresGatos
Quote from: muskrat on January 08, 2011, 06:58:06 AM
That was a big pain from what I recall. Your
elephant gift is much more useful than mine I hope [thumbsup]
'65 Honda CM91 - '98 Suzuki DR650 - '08 695+mods - '08 Hypermotard 1100S
Cher
Quote from: TresGatos on January 09, 2011, 08:58:43 AM
....Your elephant gift is much more useful than mine I hope [thumbsup]
yeah, sorry 'bout that  [evil]  Couldn't resist.  Sorry you were the one to end up with it.  Should'a gone to Marty  [cheeky]
