Did my ECU automatically adjust?
Started by scooterd145, January 07, 2011, 12:58:29 PM
scooterd145
Hi, I have a 2009 M1100s with only ~400 miles on it (bought it new ~ a month ago). I picked up and installed a set of HMF slip ones (pregnant dogin sound by the way). The first ride it did a bit of decel popping which I sort of expected (same thing happened on my S2R1K after putting Arrow cans on it). About an hour later I go for another ride and no popping (I am not complaining BTW). Just wondering if anyone else has experienced this? On my S2R I eventually put a "FatDuc" on it, am wondering if I will need to do similar (except I think it would be that duc 1-ee deal, or whatever it was called) I have not done any other mods i.e. air filter or collector.
Others might chime in, but I believe it didn't self-adjust.
If the popping was due to leaks - the leaks may have fixed themselves after being hot/cold/hot?
The Duc.EE will allow you to take off the exhaust flapper contraption, but it doesn't affect fueling like the FatDuc.
FatDuc isn't made for the new Monster, is it?
booger
I think I read somewhere that the Siemens ECU resets TPS every time the key is turned on. It was from a discussion about whether or not new Monster owners had to take their bike to the dealer after installing the Termi kits at home. Could have something to do with it, I don't know. I also read something about the Marelli ECUs not responding immediately to fuel trim changes until ridden a few miles, i.e. 'learning'. Might be a load a hooey but I'm certain I'm not making it up.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Quote from: stopintime on January 07, 2011, 02:00:55 PM
I agree.  My Termi slip-ons (with so-called "racing" ECU) used to pop on decel all the time, the ECU (designed specifically for the Termi cans remember) never learned to make fuelling adjustments to compensate for the lean state responsible for the popping.  I dont believe yours did either.
Quote from: stopintime on January 07, 2011, 02:00:55 PMThe Duc.EE will allow you to take off the exhaust flapper contraption, but it doesn't affect fueling like the FatDuc. FatDuc isn't made for the new Monster, is it?
FatDuc isnt made for the new monster, correct.  Although when you buy a PCV it comes with o2 "optimisers" which are basically the same thing (although unajustable) as FatDuc.  I happen to think that if Dynojet could be persuaded to sell these optimisers alone (as in without the PCV) that they would be the single biggest improvement to the new monster's low-end fuelling - simple, cheap yet very effective.  I also wonder why I never take my own good advice  [laugh].  But I digress.
Quote from: ungeheuer on January 08, 2011, 02:01:18 AM
just a small correction, you can adjust the o2 optimizers on the PC V.
"There are some dip switches where you can adjust the target AFR on it, but the AFR we found best for performance is preprogrammed into them, so that you can just plug and play.
Chris Kelly
Dynojet Research
2191 Mendenhall Dr. Suite 105
North Las Vegas, NV 89081
1-800-992-4993
Quote from: Raux on January 08, 2011, 03:04:11 AM
Chris Kelly
Dynojet Research
1-800-992-4993
What, so if you peel back the heat shrink there are dip SWs???  Interesting.  You'd need to know what switch combo returned which AFRs though.
Quote from: ungeheuer on January 08, 2011, 03:33:45 AM
email Chris :) he's cool and quick to respond
Quote from: Raux on January 08, 2011, 03:34:27 AM
Yeah, I know Chris is good.  I just dont care that much about it [cheeky].
scooterd145
Thanks for the clarification on the DUC.EE. ~ 700 miles now, did I mention I LOVE this bike! HMF FTW for sure too!
