February 11, 2025, 10:34:11 PM
Please Help
SEAT.
Topic: SEAT. (Read 3471 times)
Jett
Mr.Monster.
SEAT.
January 07, 2011, 01:43:36 PM »
I have a 2001 monster 748 and the seat is starting to rip and tear. Everywhere i look the seat is like $250. HOLY COW!!!! if anybody knows where i can get a good/inexpensive seat i would like to know thanks.
01 M750 Dark.
Artful
I'm glad they make pills for my
Re: SEAT.
January 07, 2011, 01:44:30 PM »
EBAY.
S2R 800 '07
Re: SEAT.
January 07, 2011, 01:51:02 PM »
$ 250 is close to a new seat, I think.
Used will be less if you can find one.
I'm not sure, but if I'm right and the seats changed over the years - look for an older type seat.
Some patience, $ 70 and a staple gun will make you able to change the cover yourself....
http://hydroturf.com/products.php?cat=Seat%20Covers%20-%20Sport%20Bike&man=Ducati
(again, not sure if it fits the older seats, but a cover might be possible to fit anyhow?)
JEFF_H
Re: SEAT.
January 07, 2011, 02:59:17 PM »
http://www.luimoto.com/product_info.php?cPath=cPath=359&products_id=142
$90
choice of colors too
S2R 800 '07
Re: SEAT.
January 07, 2011, 03:42:53 PM »
Quote from: JEFF_H on January 07, 2011, 02:59:17 PM
$90
HydroTurf not only has a choice of colors - different textures as well
Jeff, you probably know... are the seats different on older bikes?
JEFF_H
Re: SEAT.
January 07, 2011, 05:13:38 PM »
of course i know
seats models are-
93-99
00-08
696-796-1100
stock seat used should be $100-ish i would think
for $250, you should get the Ducati Performance Touring seat....its better than stock
orangelion03
My girlfriend loves my
A Most Magnificent Monster
Re: SEAT.
January 07, 2011, 05:31:50 PM »
Quote from: JEFF_H on January 07, 2011, 05:13:38 PM
Maybe. I have one of the new ones without the gel and it has a few flaws. It does locate you nicely fore-aft, but I'm not sure if it is more comfortable (have not spent more than a couple hours on it since the change). The suede-like surface is grippy (not easy to slide a cheek off), but a little loose on the foam. I've ridden the bike less than a dozen times with the new seat and one of the seams is coming undone. If you have a tail chop that uses the two mounting points at the back of the frame (where the seat lock assembly mounts) you will have to cut the bosses that the new seat has in that location. Probably would not buy one again, and spend a lot less money to modify the stock seat instead.
I should post pictures...
VIVA LA EVOLUCION!!!
arai_speed
Re: SEAT.
January 07, 2011, 06:13:05 PM »
I'm happy with my Sargent Cycle Sport Skinz:
http://www.sargentcycle.com/ducss.htm
Less then $100 bucks.
greenohawk69
Re: SEAT.
January 07, 2011, 08:24:18 PM »
What about getting your current seat re-done/upholstered? I've seen this link posted on another cycle forum I am on and others have mentioned that they do good work.
http://www.meancitycycles.com/
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty: Soap, Ballot, Jury and Ammo. Please use in this order. -- Ed Howdershelt
671M900
Re: SEAT.
January 08, 2011, 06:52:49 AM »
what's a monster 748? 748 in a monster frame? sweet.
671ducati.wordpress.com
Record of Progress!
Re: SEAT.
January 08, 2011, 10:39:17 AM »
the Monster 750 was actually 748cc if I remember correctly
671M900
Re: SEAT.
January 08, 2011, 02:52:34 PM »
Quote from: Raux on January 08, 2011, 10:39:17 AM
True, but it adds confusion though, as there's also a 748ss. You don't realy refer to the 900ss as the 904ss, right?
On eBay, look for pinwall cycle parts, they have two seats that are around $50 plus shipping. They regularly have monsters that they break down and part out.
Record of Progress!
Privateer
Re: SEAT.
January 15, 2011, 09:05:42 AM »
Quote from: stopintime on January 07, 2011, 01:51:02 PM
I'm really happy with my HTMoto seat. In fact, the one on their page is mine.
I like that every panel can be a different color and material, including the stitching. My only suggestion, were I to do it again, I wouldn't get the non-slip material where I did. It's a little too grippy when I'm wearing jeans or dickies. Not sure how it'd be with leathers.
S2R 800 '07
Re: SEAT.
January 15, 2011, 11:46:53 AM »
News from HydroTurf.....
They now offer a choice of stitching. I was hesitant about the bulky seam between A and B - just under the Ischium/sitting bones (the area with the heaviest pressure). The stitching you can see between B and C, french stitching, is now available as an option for the A/B seam. It should improve things, but I'd still prefer no stitches - so, I asked for A and B to be one piece, but didn't get an answer - which probably means "no".
Privateer: have you ever felt the A/B seam?
I was thinking "carbon" on both A and B - good idea?
Privateer
Re: SEAT.
Reply #14 on:
January 15, 2011, 04:38:15 PM »
Quote from: stopintime on January 15, 2011, 11:46:53 AM
I just went out and tested it. That seam is about an inch outboard from my 'sit bones' on both sides. I never really noticed where the seam landed so I can't say it's ever been a problem. I thought the non-slip would be a good idea to keep me from sliding forward. What it ends up doing is gripping my pants while my body slides inside. In snugly fitting leathers, probably not a problem.
as for the fabric and pattern... since mine was the first one they'd done, they didn't have a pattern. I picked the stitching and fabrics, based on the advice from my local shop. What I got is what they decided on. On mine, A D and E are non-slip and B and C are carbon.
there are some closeups and different angles here:
http://www.ducatimonsterforum.org/index.php?topic=26129.0
I apologize in advance for the izzy pictures.
