Harbor Freight Soda Blaster..
Started by TAftonomos, January 08, 2011, 10:40:04 AM
Quote from: Timmy Tucker on January 10, 2011, 12:24:33 PM
Any chance soda blasting would strip the finish off a set of corroded and peeling coffin covers? I would just as soon refinish them as buy billet covers.
soda will easily.
I have the bigger one from eastwood with the soda conversion. If you use the SMALLEST nozzle you only need 7cfm, which is still more than most compressors. Luckly i have a 2-stage quincy that pushes something retarded like 20cfm at 90psi.
I also have a blasting cabinet that i filled with glass media. i use that to texture up anything i Powdercoat. and its re-usable depending on what your shooting at.
