Harbor Freight Soda Blaster..
Started by TAftonomos, January 08, 2011, 10:40:04 AM
TAftonomos
Picked one up yesterday, with some of the coarse media.  Works great!  Def not as aggressive as a media/shell/shot blaster, but doesn't tear up rubber bushings and boots either (doing some suspension arms).   [thumbsup]
Not sure if it would blast the paint off a duc case, but I'll try it this afternoon or tomorrow morning and let you know.
Don't forget to use the 20% off coupon if you pick on up at the store.  It was $150 - 20% + Tax, whatever that works out for you.
DucHead
I've had one for a couple months, works great!!
I got a Bandit oil pan off eBay, and it looked bad:
After about 15 min. of blasting, followed by rinsing with water and drying with compressed air, it looked like this:
Jarvicious
You can use the compound they sell at HF or you can just use straight up baking soda.  I was looking at those at the store today actually.  If you don't want to drop $150 the one I was looking at was like $40 I think, albeit I'm sure it was tiny by comparison.
Orrrr, if you have an air compressor at home you can go the route this guy did.
http://www.aircooledtech.com/tools-on-the-cheap/soda_blaster/
DucHead
Quote from: mitt on January 08, 2011, 11:22:49 AM
where do you buy the soda?
If you're blasting coins, then you can buy soda at the grocery store.
For bigger (or lots of) jobs, HF sells 50 lb. containers.
gregrnel
2003 620ie red, cored stock pipes, Hit -Air jacket, nice deriere.
the smaller blaster is on sale for $99 and you can use the coupon with that.
make sure to have enough air compressor to do it
jim_0068
DucHead
This is the one I got...it was $99 I think:
triangleforge
Quote from: Jarvicious on January 08, 2011, 11:36:41 AM
Nice!!!!  I'll have to try that.
2000 Cagiva Gran Canyon
64duc
Quote from: ducatiz on January 09, 2011, 06:25:16 AM
It's going to take a lot more compressor than you might think to run continous. You only need 90 psi but you will need more cfm (cubic feet per minute) than any homeowner unit will put out.  The amount of cfm and media you use is controlled strictly by the size of the orifice in the nozzle. Bear in mind it wears with use.
94 M900, 64 Diana 250
Timmy Tucker
Any chance soda blasting would strip the finish off a set of corroded and peeling coffin covers? I would just as soon refinish them as buy billet covers.
1999 M750 - "Piggy"
2007 S4RS
Quote from: Timmy Tucker on January 10, 2011, 12:24:33 PM
yes it will.  clean and white.
il d00d
Quote from: 64duc on January 10, 2011, 11:49:15 AM
Sure, if you want to strip your aircraft carrier :) ?  See the review below, but it looks like one guy ran his 5 CFM compressor without any problems.  Even still, 8 CFM is not strictly industrial.  I am continually being told my 4 CFM unit won't run anything - it runs whatever I plug into it, I just couldn't make a living on it.  I am sure it would be fine for the projects listed here.
http://www.harborfreight.com/15-lb-portable-soda-blaster-66742.html
Doctor Woodrow
2005 620 Dark "Zerafina", High mount Termi's, Cyclecat rearsets and clipons. Axio "Repsol" Hardpack backpack. Some of us put the 'Damn' in Crash Damnage.
