Stupid question, but still confused
Started by SDkid, January 09, 2011, 03:34:48 PM
SDkid
This is going to be super noob, but I can't seem to find a definitive answer anywhere.  I bought a 2002 M750 Dark, and it says 750 Dark i.e. on the plastic panel below the seat.  I read various places that the i.e. mark indicates fuel injected, but am pretty sure I am staring at a couple carburetors under my airbox.  Am I crazy or is there some variation here?
nomadwarmachine
Look closely from the side to see if you have wires plugging into those "carbs" underneath the airbox.  The 750 i.e. is a fuel injected bike.
Scotzman
I think your bike is an "example" of a 750. I think the FI bikes are +03 or is that the SV's? Pretty sure monsters are too.
'02 is the only year the 750 Monster was fuel injected.  In fact all Ducatis were fuel injected except for the  Monster 400 which only went to a handful of markets.  Either you think the throttle bodies are carburetors, your bike has been modified or it is not an '02.
You can download an owner's manual for your bike here:
http://www.ducati.com/services/maintenance/index.do
Do you have a flashing light on your gauges when the bike is shut down?
If you lift the tank are there ignition coils and little black boxes mounted near the battery?
If the answer to the first question is yes, and the second no your bike is injected.
SDkid
Even with the high-throttle warm-up switch?  I thought a FI engine wouldn't have that.
Quote from: SDkid on January 09, 2011, 07:59:32 PM
The early, not sure about the latest, fi Ducs had manual fast idle.
SDkid
Quote from: humorless dp on January 09, 2011, 07:45:53 PM
are you talking about the yellow/orange security light that flashes for ~48hrs?  Yes I have that.  Not sure about the coils, I can check tomorrow in the daylight.  I do know there is one larger box on the right side of the battery.
Quote from: SDkid on January 09, 2011, 08:27:15 PM
Yes.
If you have that light your bike is indeed a bike that is fuel injected.
The large box...is it silver? That's your ecu.
I believe what you think are carbs are in fact the throttle bodies. There is an injector mounted on each one. It will have an electrical connection also.
SDkid
Quote from: humorless dp on January 09, 2011, 08:39:53 PM
Yes.
Gotcha.  I'll take a closer look tomorrow.  Thanks for the help.
Quote from: humorless dp on January 09, 2011, 08:11:27 PM
Not sure when it dropped off, but I know injected bikes had the fast idle through 2006.
SD - It's just a 2nd cable that runs down to the throttle cam as well. If you (have enough reach to) crouch by the right side of your bike, you'll see the cam, if you operate the fast idle you'll see it move the cam a bit.
Christian
Yeah, the carb bikes have a "choke" and the FI bikes have a "fast idle".
But your bike is definitely fuel injected.
Quote from: Christian on January 12, 2011, 12:27:09 PM
Actually the carbies have an enrichment circuit.
Not a choke.
MIGUEL
I have a have a 2002 750 senna... and i was told my bike has a choke so it has carb that it wasn't f/i. is that true...
