February 11, 2025, 10:40:31 PM *
Author Topic: Tubed vs. tubeless tires...  (Read 2255 times)
DucHead
No garage queens
« on: January 14, 2011, 12:54:43 PM »
Can one safely run tires made for wheels requiring innertubes on tubeless rims?
« Reply #1 on: January 14, 2011, 01:20:48 PM »
AFAIK, tube-type tires do not have an inside layer of airtight rubber, and thus will be slow-leakers.
That may be ancient history, though..... YMMV.
DucHead
No garage queens
« Reply #2 on: January 14, 2011, 01:28:54 PM »
Thanks Nick.
The tires in question were on a SC Sport 1000, if that makes any difference.  They came with aluminum wheels attached, and I'd like to use the tires if possible.   Grin
Wheels are for a project bike.   Wink
« Reply #3 on: January 14, 2011, 01:35:23 PM »
These guys seem to be willing to discuss tube fitment:
http://www.tiresunlimited.com/tube_information.htm
« Reply #4 on: January 14, 2011, 01:48:54 PM »
The Sport Classics didn't need tubes because of the tires, they needed them because of the rim. Because of the way the spokes thread into the center channel, the outer rim is not airtight. People have used rubber strips and RTV silicone to seal them up.
As far as I know (that is, you should check with a Duc dealer before you do anything that could injure yourself/other/your bike/me) all of the tires fitted to the Sport Classics from the factory were new-tire technology with a retro tread pattern.
DucHead
No garage queens
« Reply #5 on: January 14, 2011, 05:30:20 PM »
Thanks, I know they leak thru the spokes, but the question is can the tires be run on a tubeless wheel?
« Reply #6 on: January 14, 2011, 05:55:52 PM »
As I understand it, the Pirelli Phantom was based on the Diablo tire carcass (0* Belted Radial and all that) and can be run tubeless.
DucHead
No garage queens
« Reply #7 on: January 15, 2011, 04:11:42 AM »
Thanks.  Maybe I'll sell them to a SC owner then.
« Reply #8 on: January 15, 2011, 05:35:08 AM »
Both the Pirelli and Michelin tires that came on the SC series bikes can be used on tubeless wheels without issue.
DucHead
No garage queens
« Reply #9 on: January 15, 2011, 05:44:49 AM »
Oh, OK cool!
Dietrich
« Reply #10 on: January 15, 2011, 10:20:59 AM »
If you read the sidewall of the Michelin Classic tires I'm pretty sure they say "tubeless" on there somewhere, even though they used tubes on the stock Sport Classic spoked wheels.
DucHead
No garage queens
« Reply #11 on: January 15, 2011, 10:40:30 AM »
Thanks guys!
I stopped by my dealer today, and he said that the SCs used tubeless tires.
mendoje
« Reply #12 on: January 15, 2011, 09:12:00 PM »
FWIW, many years ago I converted the cast aluminum "snowflake" rims on my '81 BMW R100RS from tube to tubeless.  After a string of 3 flats (which deflated instantly) in 3 weeks, I had had enough.
All I did was drill out the stem holes to the correct diameter, cleaned the inside surfaces, sealed it with 3 coats of epoxy based paint, and bolted on the valve stems.  Mounted the tires, and never had any sealing issues.
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike Smiley)
http://ducatimonsterforum.org/index.php?topic=27788.0
