February 07, 2025, 07:28:13 PM *
News: Please Help
Author Topic: Quick release  (Read 1039 times)
scduc
« on: January 15, 2011, 06:56:49 PM »
I plan on getting quick disconect valves for my fuel lines. Who has done this and where/ what size did you get?
mendoje
« Reply #1 on: January 15, 2011, 10:00:40 PM »
The only brand you want is CPC, you can google it.  They have MANY types and orientations available, it just depends what you're trying to achieve.  Some BMW's come with the plastic CPC QD's, but they eventually break.  When you decide what you need, be sure to get the chrome plated brass ones, NOT plastic.  Here's one link to some basic sets which should give you some ideas, and likely they will work for you:
http://www.beemerboneyard.com/fuelsystem.html
One consideration is these fittings take up a bit of space, if you are considering stuffing them into a tight space.
2003 M800Sie / 2004 BMW R1100S / 1981 BMW R100RS (Sold) / 1977 Kawasaki KE100 (1st Bike Smiley)
http://ducatimonsterforum.org/index.php?topic=27788.0
errazor
07 S2R1K
« Reply #2 on: January 16, 2011, 08:13:46 AM »
I do believe that you already have this.
It is standard on my 07 s2r.
76 SUZUKI GT 100,  88 YAMAHA TDR 250,  07 DUCATI S2R 1000.
DucHead
No garage queens
« Reply #3 on: January 16, 2011, 08:21:35 AM »
There are about three threads on this here.  I think the search button should be removed.  laughingdp
In one of those threads, I posted the part numbers.  I got them from Omega.com
Here they are (metal with shut-off valves on both halves):
FT-LCD170-05: $24 (5/16" ID hose barb, In-line, 2.00" Length, Shutoff, Coupling body 1/4" flow);
FT-LCD220-05: $15 (5/16" ID, Hose barb, Straights, 1.85" LCD Length, Shutoff, Insert 1/4" flow).
Here's the thread: http://ducatimonsterforum.org/index.php?topic=21234.0 (look 3/4 of the way down page 1)
BTW, a good tip from Spidey (or maybe it was Speeddog):  orient the feed and return disconnects in opposite directions.  That way, you'll never mix them up.
scduc
« Reply #4 on: January 16, 2011, 12:37:05 PM »
The lines do "quick release", but they do have automatic shut off. Thus when I removed my tank, gas leaked every where. I do not want this to happen again.
I did a search, I guess I didn't do a good enough job. Thanks for the info.
« Reply #5 on: January 16, 2011, 05:29:18 PM »
They should shut off, they will leak a bit until the internal lines are empty, but that should be it.
