Sliders: Rizoma, Speedymoto or ???
Started by dgm, January 19, 2011, 07:44:28 AM
dgm
I think my 696 is just about ready to take to the track in the spring for my first track experience.  I think I should probably do some sliders though, but can't decide which ones.
I really like the more subdued look of the Rizoma's: http://www.motovationusa.com/mvstore/Scripts/prodView.asp?idproduct=395
But the Speedymotos have such a good rep (and a little more expensive): http://www.monsterparts.com/pc/09-0201/Protection-Slider/09-0201.html
I'm also can't decide on the front and rear axle sliders: Speedy, Rizoma or Rhino?
http://www.monsterparts.com/mm5/merchant.mvc?
Any opinions?
2009 696, Termi CF Pipes ECU Intake, Woodcraft Rearsets, Fender Elim, Shorty Pazzo Levers, CRG Lane Splitters, DP Low Seat, Powder Coated Bits, Speedymoto Frame Sliders, Rizoma Front Sliders, Rhinomoto Rear Sliders, Shorai Batt, Billet Oil Cap, iPhone Mount, LED Blinkers, Leggero Sprocket Cover, TPO Corsa Crankshaft Cover, Canister Delete/Euro Shroud, 14T Front Sprocket
i dont have forks sliders, bikes been down about 7 times. Forks never touched. Generally speaking, fork sliders just dont work, and if ur in a situation where u need em, chances are ur forks are make the beast with two backsed anyway...
other thne that rizoma! Rear axle sliders? Some of them double as a spool, so thats the only reason id get them.
just realize that the smaller the frame slider is, the more it is JUST a frame slider. The longer it is, the more it will protect the body work if u get what i mean.
orangelion03
I have T-Rex sliders on mine.  Relatively inexpensive and they did their job twice, once on each side.  Replacement plastic was $13.  I have axle sliders as well, and the fronts made contact with asphalt on both falls, though they only rubbed off a small amount and didnt need replacement.
VIVA LA EVOLUCION!!!
Bishamon
I have FastBikesUSA frame and axle sliders on my Sport 1000, and I am very happy with them, both in terms of looks and ease of installation, but they have never been "put to the test".
I plan on getting some for the frame and front axle of my M796 as well.
2011 Monster 796
2007 Sport 1000 SE (SOLD) :(
Kev M
Anyone got pics of their 696 with sliders installed?
And am I reading this right, that frame sliders alone MAY be sufficient, at least in a low speed drop or standing tipover?
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
asherrick
I have Motovation frame sliders and Rizoma axel sliders (front & back) and bar ends on my 696. The wife took a low-speed spill and the frame sliders worked great. The axel sliders took a small amount of damage though I'm not sure that they protected anything since they were barely touched.
'09 M1100s
BlackKat
X2 for the T-REX...$45.00 and they do the job just fine. Just ordered my 2nd set for a different bike... I can say I have EVERYTHING Speedymoto offers and I just don't see the point in spending a ton of money on something that is made to take a hit.
On a side not, they provide amazing service. He offered to do some custom machining on my first set as one of the mounting points on the older style frames has a tendency to be over painted/powder coated from the factory-but only in some cases. He turned one down a couple millimeters upon discovery of this and next dayed me the part free of charge.
R0CKETMAN
I went with these...got the fork sliders too. I don't test them like He Man though [cheeky]
http://www.motovationusa.com/mvstore/scripts/prodView.asp?idproduct=510
DucNaked
Quote from: R0CKETMAN on May 05, 2011, 08:18:50 AM
I also have the Motovation sliders. Haven't tested them yet.  [thumbsup]
Kev M
Ordered the Motovation sliders - will report back after install!
Thanks guys!
Kev
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
Kev M
So it only took almost 2 months but the Motovation Frame Sliders just arrived today from Pro Italia.
They look well made and (using my bike jack to support the motor with a block of wood just to be sure nothing fell out of alignment) they installed in about 10 minutes.
Glad to finally have them.
Now to purchase some axle sliders....
Current Fleet
18 Guzzi V7III
16 FLHP (Police RK)
13 Guzzi V7
11 M696
wannabfast
yea i was shocked to find that it only fits in one way
