More Chop Chop
Started by sejman, January 19, 2011, 10:24:58 AM
sejman
A while back I attempted to chop my stock exhaust but was stymied when I could not budge the outer aluminum sleeves, so I resorted to a less radical procedure involving only drilling a bunch of holes in the rear wall to open up that last chamber.  The improvement in sound was great, but I was still left with stock cans that protruded way out the back of the bike after chopping the tail.
Thanks to some encouragement from caffeinejunkee, I finally went back and did it the right way. I gambled that if I chopped the cans with the sleeves in place that I'd be able to budge them easier after the chop and I was right.  The simplified procedure: remove cans from bike, position in chop saw (I took 3.5" inches off), remove sleeves from the cut-off part and cut welds to remove end caps, slide sleeves down and debur/clean chopped ends, rivet end caps back on.  The whole job took about 2 hours with removing the end-cap welds the toughest step.  I learned from the first one that the easy way to cut the welds is to not attempt to grind through the weld itself - just use the cut-off wheel (I used a 3" wheel attached to a regular 3/8" drill) to cut through the sheet metal of the end cap just above the weld.  Piece of cake and plenty of end cap flange left for refastening.
I'm considering painting the cans with a high-temp black wrinkle (like used on some valve covers, etc.). Opinions?
Pics and video:
Before:
https://www.flickr.com/photos/sejman/3503253014/#in/set-72157607797890204/
After:
https://www.flickr.com/photos/sejman/5361550662/#in/set-72157607797890204/
https://www.flickr.com/photos/sejman/5360941471/#in/set-72157607797890204/
Video/Sound:
jim_0068
sejman
#2
Not sure what I'm doing wrong - posting links from my Flickr account (verified as "public") using the [img] code...argggg
OK - just figure it out...Flickr needs full links now for some reason, no longer allow embedded images.
caffeinejunkee
Sweet, man!  [thumbsup]
When I painted mine, I used Dupli-color engine enamel (ceramic, 500-degree, gloss): I prepped by cleaning with thinner and sanding with 200. I used steel wool between 4 coats. I painted two sets that way, and both held up well.
Jarvicious
That sounds fantastic.  I think I was expecting a little more of a chop.  Those guys must have been pretty long in the first place.
sejman
Thanks - I am very happy with the sound, and yes, they were very long to start with.  My goals was to get them inside the rear tire which I just achieved with 3.5" removed and this left the Ducati embossed badge/lettering just barely fully intact.  Now after having done this, it would be very simple to chop more off. I don't think it would change the sound much unless you chopped so much that you breach the middle of the three chambers (from my understanding of the internal construction). Once I've committed to the painting I may chop more since the print on the cans would be covered anyway.
