February 14, 2025, 08:06:58 AM
Some Powdercoat and new dampner on the S4R ..pics
Topic: Some Powdercoat and new dampner on the S4R ..pics (Read 4356 times)
venomousr1993
Snapping Like a Squirrel
January 22, 2011, 06:28:06 AM »
Bike is snuggled away in my basement and since my hip and knee surgery in November, I have been cleaning and getting the bike ready for this spring.
Took some parts off and sent over to my powdercoater. He matched up the headlight trim perfectly. I did the clutch cover, stock rearsets, pegs, headlight brackets, and handlebar mount.
Bike got new front/rear Michelin Pilot Power 2CT's, new Brembo HH pads, clutch stabilizer plate, fresh fluids and I picked up this Ducati FG Gubellini Cross Mount Steering Dampner. I got it off EBay new for 250.00 and contacted FG in Italy for the base mounting studs that go around the ignition. 280.00 in it...I felt good since it is 600.00-750.00 everywhere I looked.
The tank needs to come off and get fixed...I have developed the notorious tank hinge seep. I know this cold weather in DC has not helped either. She also needs new belts and valve adjustment before I start riding again.
Next winter, the swingarm and triples will be powdercoated the same black color. Bit by bit
Before:
In basement now: (no slip ons on it)
Powdecoated parts:
Last Edit: January 22, 2011, 06:39:52 AM by venomousr1993
WERA Expert #163
Leo Vince
http://www.leovinceusa.com/
Lucas Oil
http://www.lucasoil.com/
WoundedWear
http://www.woundedwear.org/
AXO
http://www.axo.com/us/
venomousr1993
Re: Some Powdercoat and new dampner on the S4R ..pics
January 22, 2011, 06:29:26 AM »
My dampner I scored on...
WERA Expert #163
Leo Vince
Lucas Oil
WoundedWear
AXO
TitanMonsterS4R
January 22, 2011, 10:38:50 AM »
Quote from: venomousr1993 on January 22, 2011, 06:28:06 AM
Before:
Powdecoated parts:
Bike looks amazing. Who's your powdercoater am located in DC as well.
lazylightnin717
January 22, 2011, 01:29:49 PM »
Why would you spend 280 to get your bike wet?
I'd buy a hose to dampen it....
(for future reference, it's a damper)
Bike looks good though. I never liked that clutch cover but it works in your case
Comes a time
Says don't you see
Gotta' make it somehow
booger
January 22, 2011, 05:40:11 PM »
I want yer bike
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
muskrat
January 22, 2011, 06:10:30 PM »
looking real nice.
just for kicks here's what she'll look like with a pc swing arm (got the same bike
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
venomousr1993
January 22, 2011, 06:20:43 PM »
Quote from: muskrat on January 22, 2011, 06:10:30 PM
looking real nice.
Thanks for the pic..helps out a bit.
Is the front fender the 916/748 front fender? I had been looking at doing it, but wasn't sure on how it would look. Do you have and better shots if it is that particular fender.
WERA Expert #163
Leo Vince
Lucas Oil
WoundedWear
AXO
venomousr1993
January 22, 2011, 06:36:04 PM »
Quote from: MadDuc 20/20 on January 22, 2011, 10:38:50 AM
I used G&T Powdercoating...they are down in Fredericksburg. Terry is his name and he is super nice. He did my rearsets at a lower temp as not to mess up the rubber bushings. He prefers to do it when it is warmer as it gives a nicer finish than when it is overcast and freezing outside. He met me close to my work on Quantico to pick up and drop off the parts. 540-220-5094
Last Edit: January 22, 2011, 06:38:15 PM by venomousr1993
WERA Expert #163
Leo Vince
Lucas Oil
WoundedWear
AXO
muskrat
January 22, 2011, 06:41:35 PM »
916 fender.
I also pc'd my triples and handle bar. the only thing I regret not doing is the lowers on my forks.
You might also look into an Evotech radiator cover, complete blacks out the front and makes the radiator vanish...if you're into that look.
2015 MTS 1200
09 Electra Glide
dan_t
January 23, 2011, 12:29:22 AM »
Hi, great looking bike!
I've got an '08 S4RS & am considering gettinng the hanging rear passenger pegs & exhaust bracket powder coated in the same matt black as the swing arm.
Only question in my mind is whether getting the full pegs done will make them a little slippery if someone is on the back.
What's the result with yours?
'08 S4rs;
Termis, DP C/F Short Tail, DP C/F Rear Hugger, Custom hand-made seat, Matris Steering damper, Pazzo Shorty Levers, Rizoma Dynamic mirrors, EVR Ventilated Pressure Plate, EVR Open Clutch Cover, SpeedyMoto Stainless Springs Kit, EVR Clutch Slave Cylinder, EVR Front Sprocket Cover, Evotech Performance Radiator & Oil Cooler Guards, Rizoma CT027R, CT017R & CT015R red fluid reservoirs, Powder Coated Rear Passenger Pegs, Oberon Racing Pegs, C/F Fairing stays, Oggy Knobs, ZG tinted Screen
muskrat
January 23, 2011, 07:27:49 AM »
I've never had an issue and use Alpine Star boots.
2015 MTS 1200
09 Electra Glide
