Anyone use a Vibranator?
Started by arai_speed, January 25, 2011, 09:58:38 AM
arai_speed
No, this is not some pun like "worst blow job" or "get nakid" This is actually the name of the product:
http://www.vibranator.com/ProductDetails.asp?ProductCode=09-635-710-N-002-B
I saw it the other night while reading RRW and thought it sounded interesting.
looks kinda like the Motovation bar ends. I have a set of those on one of the bikes, and think they are well made.
arai_speed
Quote from: a m on January 25, 2011, 11:16:05 AM
Yes - they look similar.  Did you feel any difference w/the motovation set vs. stock?
yes, and the finish is nice - they aren't on my main ride though
Looks promising, but I'm left wondering if it might make things worse if it wasn't used on the right, specific bar type.
i.e. with some bars (if it happened to resonate at a different frequency) it'd damp the vibration. On others (if it happened to resonate at the same frequency) it'd make it worse.
BoDiddley
Yep they look the same as the motivations but without the o-ring which is needed for a real tight fit.  The motivations are the same but made better for a little less, IMHO.
"But sire what are we to do.  You have taken all our weapons and now the heathen hordes are at the gate.  Are we to lie down and give them our lives.  Without weapons they will make us eat ourselves."
muskrat
those are pricey.
on another note, I thought this was going to be an R rated folder for a minute.  :-[
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
you're thinking vibrider again.
The theory makes sense, but:
Quote from: Drunken Monkey on January 25, 2011, 12:16:18 PM
Though I suppose if you've got clip-ons, it would be possible (in theory) to "tune" your bars via things like material, material thickness, and overall length of clip-on, making things like this unnecessary.
Anyone have any FHE with how in-bar grip heaters affect handlebar vibration? I'd think they would serve double duty, keeping your mitts toasty while damping some of the worst vibration. Again, I suppose it would depend on the resonant frequency of the whole system.
I don't know exactly how these work, but wouldn't it simply be that they are shaking/vibrating
by themselves - kind of meeting the bar coming in at the opposite direction?
Sort of.
There are a couple of forces at work.
One is resonant frequency, the other is simple energy absorption.
The resonant frequency of a bar is going to be influenced by a lot of factors: bar material, tubing thickness, overall length of clip-on or distance from bar mount, control placement, etc, etc. By adding a piece to the bar, you're changing its dynamic. As an example, think of a guitar string. A set mass at a set tension at a set length with a set thickness creates a set frequency.
The other force at work is, as I said, simple energy absorption. F = MA. By adding mass, you can decrease the acceleration forces exerted on the bars. Less acceleration, all else being equal, means that the oscillations are less intense.
DucatiSTi
These might work - stole idea from cycling
http://bontrager.com/model/04579
Not sure if they fit
2009 696 Monster - Arrow Carbon slip-ons, Bitubo steering damper, DP oil cooler, DP Touring Seat, Rizoma tail chop, Rizoma Zero 11's, Stebel Nautilus horn, Ducati Euro shroud, Speedymoto sliders (axles and frame)
BoDiddley
Except for cost the ultimate dampner would be mercury filled so it would work like a recoil reducer.   [coffee]
Quote from: BoDiddley on January 26, 2011, 12:36:41 PM
Meh. If cost wasn't an issue, I'd go with depleted uranium.
Also, there's no "n" in damper.
[coffee]
Quote from: Buckethead on January 26, 2011, 05:46:15 PM
[coffee]
No "n"?
Handle Bar Dampener Kit
