new helmet cam
Started by tilt, January 25, 2011, 01:36:16 PM
tilt
I found this today, i figured some of you might be interested in it.
http://www.engadget.com/2011/01/25/contourgps-helmet-cam-review/
Airborne
The contour has been around for a while and believe the gps model became available not too long ago. I work with every type of helmet cam putting them on test vehicles and the main advantage of the contour is that it works easier as a helmet cam. The gopro is more awkward on the head and has a more sophisticated start up sequence. The contour you just flip a switch so it is perfect for giving it to someone who is unfamiliar with operating. In my opinion its also a safety issue as I am constantly checking the gopro while the contour is more set and forget. A situation like that is especially dangerous when you are using it on a moto.
2007 Monster S2R, Vespa GTS 300, 23 Triumph Tiger 900 Rally Pro, Vino 125
