ARE ANY OF THESE WORTH IT ?
Started by DarkMonster620, January 29, 2011, 06:40:25 AM
Quote from: humorless dp on January 29, 2011, 09:12:13 AM
I think you have a problem that the device isn't going to fix.
You need to set up your injection first and go from there.
Do they use ethanol fuel in Panama?
No, no ethanol ... venezuelan fuel ...
Can anyone tell me where to get a Matthesis? ... or some diagnosis tool for my Gina?
Do a search Carlos. There have been a bunch of threads regarding the different options.
Quote from: humorless dp on January 29, 2011, 10:02:11 AM
I'm doing that ... just that ... with everything that's going down here ...
Quote from: Darkmonster620 on January 29, 2011, 10:22:19 AM
call Chris about the VDSTS...
You kind of need access to an EGA also.
Quote from: humorless dp on January 29, 2011, 10:30:49 AM
EGA ...
D'Uh ... Got access to one for free ... but, will contact LT to see if he still has the Gunson unit available ...
Carlos, 8% is richer than 12:1 air fuel ratio, 12 is surely off the charts, like I said, much too rich.  Been that way the whole 40 some odd years of my automotive experience.  Bet your plugs are nice and sooty in a few hundred miles.   4% is about 13:1.
If LT doesn't have the Gunson google will find one for you.
Quote from: howie on January 29, 2011, 02:33:27 PM
OK, but why then those percentages where in the 'green zone'? It's and EGA that I've never used, Made in PRC ...
Quote from: Darkmonster620 on January 29, 2011, 03:01:30 PM
Because it was made in PRC? :P
Quote from: humorless dp on January 29, 2011, 03:05:59 PM
I mean, accuracy ... don't know, values shown where in 'green zone' and user manual said, 'values in green zone are considered OK" .. not verbatim, but, you get the idea ...
I'll see when I come back if I can get my hands on the Bosch EGA, the BEA350 ...but, how do I do it, it has only one hose and my bike has two exhuast pipes ... ???
Quote from: Darkmonster620 on January 29, 2011, 03:11:25 PM
The one my tech uses has two connections I think...and he puts them in the ports in the pipe not the mufflers.
Remember the exhaust has a crossover that connects to the mufflers.
Dunno, but they are wrong.
Quote from: humorless dp on January 29, 2011, 03:13:47 PM
which ports ... went outside and saw no other holes appart from the ones at the pipes ...
Quote from: Darkmonster620 on January 29, 2011, 06:10:33 PM
There are plugs in the tubes before the crossover....one for vertical and one for horizontal.
They can be a real PITA to remove without stripping.
Quote from: humorless dp on January 29, 2011, 06:33:39 PM
uh oh ... think my headers don't have those ... the old ones did ... curios thing, this header is OEM and I see no plugs ... telling ya ... me screwed by Ducati ...
