ML's machine shop thread
Started by Monsterlover, January 31, 2011, 03:39:33 PM
I guess I should update this thread, huh?
Some pics of recent work
.200" face cut
Mrs SMT cutting pipe on the saw
What happens when you pop your part out of the jaws and it gets flung around and trapped against the turret
Super Duplex Stainless, started as 9" round solid. This shit is no joke to cut. Get it wrong and it will own you. I have it figured out.
Boring some cast stainless tube with a dampened boring bar. You can stick it way out and it won't chatter. It's awesome.
Smokin'!
A small parting gift from some 1045 steel shafts I was cutting. Big chips. Big, hot, chips. This one stuck between my neck and my hoodie, which proceeded to press it into my neck more. All over in less than two seconds.
Sometimes I really wish I had larger equipment. This is all the clearance I had between the part and my drill. I measured it. .02". Twenty thousandths of an inch.
hooligan machinist
Nice hickey ya got there, playa. [bow_down] [laugh]
cell # (931)-316-2020
I have five more to put up...
Here's the rest
2" Sandvik 880 in stainless:2" Sandvik 880 in stainless
Drilling Super Duplex: Drilling Super Duplex
Milling a grease groove on Okuma LB300-M: Milling a grease groove on Okuma LB300-M
5/8-11 tap in Super Duplex: 5/8-11 tap in Super Duplex
Tapping a 1/2-13 thread in Super Duplex: Tapping a 1/2-13 thread in Super Duplex
Thanks for fixing the links, Painter [thumbsup]
WTF?
No pecking on the drilling ops?
No coolant on the tapping ops?
Where is the machinist to english translation function?
Quote from: Speeddog on November 02, 2014, 08:42:27 PM
WTF?
Nope. Those drills aren't even carbide. Mfr rep didn't recommend pecking. Ran awesome. I don't have coolant through the spindle on that machine either ;)
I did use some Union Butterfield tap goop, so it's not quite the same as dry.
The machining forums all told me I couldn't tap super duplex and to thread mill it instead :D
Quote from: Grampa on November 02, 2014, 09:18:47 PM
I thought pictures would cover it ???
hooligan machinist
Quote
WTF?
Peck drilling tough materials has it's own set of problems.
In vertical applications loose chips can wedge between the drill tip and the bottom of the hole.
This forces the drill to push through the obstruction rather than cut.
Bad news for drills.
Quote from: hooligan machinist on November 04, 2014, 06:42:59 PM
Can also work harden stainless and sooper duplex ;)
