ML's machine shop thread
Started by Monsterlover, January 31, 2011, 03:39:33 PM
So you're saying that Super Duplex is difficult material, but you can drill it with non-carbide drill with external coolant.
Quote from: Speeddog on November 04, 2014, 07:47:04 PM
Yes.
I did some SD rings that got holes with counter bore for cap screws. The through hole was .406.
I got 6 holes with solid carbide. Barely.
I called my precision twist drill rep and he recommended a high performance cobalt drill. Said his software predicted 200 holes.
Yeah right, I said.
Sure enough, I got 200 holes. The drill looked a little rough but I'm actually still using it when I have need for that size.
We are basically 100% Sandvik at our shop. After this was all said and done I looked in their book and they don't even list cutting data for super duplex in the carbide drill section.
Must have been a reason.
Lesson learned. I have no fear of the stuff now that we have a solid method established.
Someone who doesn't know the material and just guesses how to run it instead of asking for help will get murdered by it.
cokey
Did you ever get that big contract?  Thread went dead after that...
I WIN
About the goat...
I did not. My customer can't get a response from the end user.
Such is life.
Got something else cooking though.
Quote from: Monsterlover on November 05, 2014, 02:59:52 AM
~~~SNIP~~~
Yeah right, I said.
~~~SNIP~~~
That's astonishing.
Quote from: Speeddog on November 05, 2014, 12:49:53 PM
That's astonishing.
You're not kidding. After a while I stopped watching the load meter. That progressed to turning my back to the mill while it was running. That progressed to loading parts and walking away.
hooligan machinist
 Work hardening is the real issue with any stainless.
Cobalt and high speed steel drills will work wonders when you get them dailed in on the feeds and speeds.
My rule of thumb is speed kills. Lower RPM's and higher feeds with break up chips without generating great amounts of heat.
But when it comes to 17-4 PH, All bets are off. That shit will work harden just being loaded into the machine. [laugh]
cell # (931)-316-2020
hooligan machinist
#1358
 I've seen 17-4 PH literally untwist a drill. While being flooded with coolant. [bang]
Untwist?  That shouldn't happen...
Solid carbide tears it up pretty well, especially with 1000psi coolant through :)
Back to 7 day work weeks for me for a while.
December is booked and so is most of January.
make the beast with two backs yeah!
Still taking on work for January!
I got orders for a couple things I didn't really want to do so I put crazy money on the jobs and still got the work.
SpikeC
 I remember hearing somewhere way back when that if the customer doesn't say ouch! you didn't charge enough!
Spike Cornelius
  PDX
2008 Bimota DB5R  woo-Hoo!
   1965 T100SC
Been a while since i updated.
Induction hardened hydraulic rod. We milled the flats and thread milled the center.
Hydraulic cylinder. Faced about 3/16 off the first end and bored a 20° chamfer with no support. OD turned using a live center and face plate I made.
New guy had a mishap so I get to do a turret alignment today.
Scored this awesome dial bore gage set on eBay. .057"-.800" in .0001" increments.
Aluminum-bronze thingy. Machined complete in the lathe.
14' tie rods I threaded.
