January 25, 2025, 09:48:44 AM
Please Help
Statler
ML's machine shop thread
94
95
96
97
124
Topic: ML's machine shop thread (Read 319216 times)
Re: ML's machine shop thread
Reply #1410 on:
August 13, 2015, 05:37:26 PM »
Quote from: Monsterlover on August 13, 2015, 05:19:23 PM
You pulled that last post as I was responding
...and I type 2 fingers.
The best kind of whore is a
Reply #1411 on:
August 13, 2015, 06:08:57 PM »
Yeah but almost 60,000 times.
You've had practice
Reply #1412 on:
September 07, 2015, 12:20:20 PM »
The new saw is a BEAST!
Reply #1413 on:
September 07, 2015, 12:26:36 PM »
Video?
Reply #1414 on:
September 07, 2015, 12:27:58 PM »
It's not all that exciting to watch a saw do it's thing
Reply #1415 on:
September 07, 2015, 01:31:24 PM »
Quote from: Monsterlover on September 07, 2015, 12:27:58 PM
You seemed pretty enthused about it,
Reply #1416 on:
September 07, 2015, 01:34:41 PM »
I am, believe me.
Reply #1417 on:
September 07, 2015, 02:01:58 PM »
Some folks are easily entertained.
It should cut impressively!
Reply #1418 on:
September 14, 2015, 05:59:08 PM »
Cutting a 9" round bar of 316 stainless.
About 25 minutes so I didn't bother with video.
And every once in a while a machine needs it's coolant removed and changed out for new. This one stunk like a corpse so we got after it the other day.
I use a pneumatic unit that uses air to create a vacuum in a 55 gallon drum through the little bung. The big one gets the suction hose.
If the drum has a weakness, this rig will find it.
Feral 859
Reply #1419 on:
September 14, 2015, 06:55:35 PM »
Holy shit!!
DesmoDiva
Reply #1420 on:
September 15, 2015, 03:28:13 AM »
So how long does it take to go from stock round to finished widget?
How many cuts do you get out of a saw blade?
316 isn't soft.
'01 ST4 Yellow
'02 ST4s Yellow
Omnipotent Potentate
Personal Pretext
Reply #1421 on:
September 15, 2015, 03:33:11 AM »
Well, if the widgets a 3x hockey puck replica in 316 steel... not long
Going to guess this ones a good challenge. Even that "small" cut off bit looks like it's good and heavy to move from process to process. How much did that full length of 316 weigh ML?
Reply #1422 on:
September 15, 2015, 04:10:29 AM »
Quote from: DesmoDiva on September 15, 2015, 03:28:13 AM
316 isn't soft.
Depends on what you're making. These parts are probably 30-45 minutes to fully machine. We'll remove around 100 pounds of material from that 8" long blank.
Saw blades can last quite a while when you run them correctly. I don't have a base line for the new saw yet. It's got better coolant, better supply of coolant to the cut, thicker blade and a longer blade, and this saw is much more rigid than the old scissor style saw I used to have.
Life will be in hours but I'm not sure how many just yet.
Quote from: Slide Panda on September 15, 2015, 03:33:11 AM
I don't know how long that piece was since it was customer supplied. 9" round 316 is 220 pounds per foot though. That was probably 2000 pounds or so at least.
316 isn't soft.
Is really not bad. We look at it the same way we do low carbon steel. This particular job required a lot of OD roughing. We push a plate against the face of the raw blank with the hydraulic tail stock to support and "capture" it. I will take a .25" radial cut at 600sfm and a feed of .012"/rev. The machine has the spindle power to do more but the Z axis thrust is maxed out. I can't push the cutter into the material and harder without over loading the servo.
It's like someone is pouring chips out of a bucket into the machine for five minutes straight
Reply #1423 on:
September 15, 2015, 04:23:47 AM »
Quote from: Monsterlover on September 15, 2015, 04:10:29 AM
<snip>
That's worth a vid...
Personal Pretext
Reply #1424 on:
September 15, 2015, 04:27:19 AM »
So ML - you going to get into the additive making milieu?
94
95
96
97
124
