Monster 1000 Engine compatibility
Started by UberRacing, February 01, 2011, 06:58:14 PM
UberRacing
Does anyone know if a 2005(6) S2R1000 (DS1000) motor will fit in a 2005 Monster 1000S? I'm not sure since the M1000 is the dual sided swingarm and the S2R1000 is SSSA.
Thanks!
zooom
I think(?) that the casing for the swingarm mounting is different due that difference...but someone like Duck-Stew or otherwise technically minded can answer for sure.
2010 KTM 990 SM-T
I'm thinking it is the same despite the different swingarms. I think we've seen a project where a guy put a S2R1000 swingarm on dual sided swingarm Monster. That would indicate compatability.  However, I don't really know. Someone with more technical knowledge will come along and post soon.
671M900
I think the swingarm shouldn't matter. You can put s*r rearsets on a dss monster if you have the pivot, indicating they have the same dimensions. The swinger is a bit different I think due to the top mount. The m620/695 I saw with a sss I think had to invert or rotate the shock a little to get it to fit.
671ducati.wordpress.com Record of Progress!
UberRacing
ok thanks. Seems worth a shot but I was hoping someone may have the
measurements (inside the swingarm verses width of the motor mounting point) before I would
commit to buying. I could also check with a dealer mechanic....
You could try derbyed the same question in the Tech section.  You should get a more definite answer there.
Yes.  Both the '05 M1000S and the '06-'08 S2R1000 have the wide swingarm pivots.  I have done this swap a few times.
UberRacing
very cool thanks for the confirmation!
krista
Actually, the telling factor is whether the frame extends down to the swingarm pivot.
If the swingarm pivots without a frame, it's the "wider" case with the swingarm pivot bearings in it. Like the S2R family.
If the swingarm is "supported" by the frame it has the 916 type swingarm pivot. Like a multistrada.
Blue
Quote from: chris on February 10, 2011, 12:49:19 AM
So, one could put a M1100 engine in a hooped framed M900, should they be so inclined.  Correct?
krista
There's a long term plan; 1100 DS, DP cams, thin head gasket, split FCR 41s, ignitech, 100 hp [drool].
Quote from: Blue on February 10, 2011, 08:10:39 AM
Your M900 exhaust won't fit, the throttle bodies will fight with a frame crossmember, etc.
Not what I'd call a bolt-up, but definitely feasible.
Also, all Ducati motors from 2001 & up have 12mm engine mounting bolts so you'll have to deal w/that on an earlier frame'd swap.
evoasis
The problem I experienced with my 620 with a 1000DS swap was the headers not matching at all...
I guess there are good and bad mods; you'll find the good ones here ;)
