February 12, 2025, 08:00:05 AM
LED Tail light/Turn Signal
Topic: LED Tail light/Turn Signal (Read 7481 times)
Bogie
February 02, 2011, 02:25:08 PM »
Can anyone recomend a good intergrated LED TAIL Light/Turn Signal for the Monster (preferably the older style)? Last post I saw was from 2008 and I know alot has changed since then. Thanks
S2R 800 '07
Re: LED Tail light/Turn Signal
February 02, 2011, 02:41:48 PM »
Maybe not... the previous generation Monster doesn't see many new aftermarket parts being made.
I try to stay updated on new products and can't say I've heard about new lights.
Call Jeff and ask his opinion about lights....
http://www.monsterparts.com/c/Elec-Head-Tail/Elec-Head-Tail.html
....or
http://www.desmoworld.com/shop/de/ducati-monster/s2r-s4r-s4rs-1/elektrik-1/rucklicht-2
Before I got my ViziTec taillight (not made anymore) I had Clear Alternatives, but some people have bad quality experiences with them.
Other than the ViziTec, I have not seen integrated turn signals working well. The light output is too weak and positioned too close to the center - could be a safety concern - IMO. (sorry, had to be mentioned)
Timmy Tucker
Banninated
February 02, 2011, 10:20:37 PM »
I have the Motodynamics V2 on my '99 m750. Installation couldn't be any easier as long as you read the directions. Works great, lights are plenty bright. (wish I could say the same for my front turn signals
) I like the attention-getter flash when you put on the brakes. I like to think it helps w/ the cellphone-impaired make the beast with two backstards behind me.
94-07 Ducati Monster Sequential LED Tail Lights with Smoked Lens
Here it is on my bike:
1999 M750 - "Piggy"
2007 S4RS
FIFO
Doing the latter
February 02, 2011, 11:41:01 PM »
+1 on the motodynamic just fitted one with a dark smoke lense
http://www.motodynamic.com/index.php?cPath=17&osCsid=kovajoaeoc4sci1cl3p008mqi4
Monster Dave
February 03, 2011, 08:51:25 AM »
I've only had one, but been very pleased with it. It's a Clear Alternatives dark smoke tail light/turn signal.
Check here:
http://stores.motolume.com/Categories.bok?category=Ducati+Tail+Lights:Monster+(except+for+696/796/1100)&nval=22_3
Works/looks just like this one:
Last Edit: February 03, 2011, 08:54:18 AM by Monster Dave
Punx Clever
February 03, 2011, 11:41:11 AM »
Quote from: Timmy Tucker on February 02, 2011, 10:20:37 PM
I've had bad experiences with the MotoDynamics unit... The glued-on lense would literally fall off. They replaced the first one for free (and left me with the guts), so when it happened again I just modified the unit so I could put a screw on clear alternatives light. Just had unsolder and extend the leads on a few LED's for the lens posts to fit. But still, I was really unhappy with that fact.
2008 S2R 1000 - Archangel
The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over. - HST
Hank025
February 03, 2011, 12:40:41 PM »
Whats the consensus about the Ebay tail lights from China?
2007 S2R 1000
February 03, 2011, 12:56:12 PM »
Quote from: Hank025 on February 03, 2011, 12:40:41 PM
when i went to the Intermot here, i saw several chinese companies that supplied lights. all DOT or Emarked and several that I recognized as OEM.
I would say that buying direct from the source isn't a bad idea, just make sure you get the one's that are marked for your area if you get inspected.
Bogie
February 03, 2011, 04:09:16 PM »
Has anyone used Lightwerkes?
http://www.monsterparts.com/p/TLDMON/Light+Werkes+LED+Integrated+Taillight.html
Or MotoTuner?
http://www.moto-tuner.com/product_p/mt-lt-5060ledw.htm
How can you tell which tail light assembly's are good? Or do you have to physically see them to know they are bright enough? Is there a rating which can tell me the brightness, like lumen? Thanks.
Timmy Tucker
Banninated
February 03, 2011, 04:48:21 PM »
I haven't tried the tail lights, but I've got chinese turn signals up front. They look great and were dirt cheap, like $18/pr. However, the chinese shit is rarely exactly the same as what's pictured in the ebay listing. I got these these, even listed w/ the same pic (different seller though):
Despite what the pics show, they only have 6 led's in them. They're so dim that you can't really see 'em on a sunny day. Night time is a non-issue though.
1999 M750 - "Piggy"
2007 S4RS
Heath
February 03, 2011, 10:31:38 PM »
Is there a way to turn off the brake flasher on the Motodynamics one? Seems like the Motodynamics paired with a ViziTec SupaBrake flasher would be the best of everything. Even though the flasher costs as much as the taillight.
2007 Ducati Monster S4RT
Timmy Tucker
Banninated
February 04, 2011, 08:21:54 AM »
Not sure. I'll check this evening after it stops raining.
1999 M750 - "Piggy"
2007 S4RS
eyduc
February 06, 2011, 10:13:18 AM »
For my brake flasher, I wired in a Tridon EP35 electronic flasher. It is only $7 or so on eBay or $10-12 at the local auto parts store. For an LED brake, you still need a resistive load to trigger the flasher. Also, on mine I needed a diode to isolate the circuit from the running lights.
BoDiddley
S4Rs In Michigan
February 13, 2011, 02:13:21 PM »
The best ones made IMO
http://www.lockhartphillipsusa.com/store/home.php?cat=383
"But sire what are we to do. You have taken all our weapons and now the heathen hordes are at the gate. Are we to lie down and give them our lives. Without weapons they will make us eat ourselves."
Chris in SCruz
Reply #14 on:
February 21, 2011, 09:39:06 AM »
Quote from: Bogie on February 02, 2011, 02:25:08 PM
I've had a Clear Alternatives integrated unit on one of my bikes for a couple years & have no complaints. As a result, I just bought a similar unit, with smoked lens, for my 99 Monster.
Keep in mind for most of these you'll need to do something about your license plate light. Some of the little white LED strip-things out there are junk & don't last long.
