07 S2R1000 w/ 400 miles... is valve check necessary?
Started by gr1976, February 10, 2011, 06:29:51 PM
gr1976
I recently purchased this bike and am going to change the belts because of the age.
While I am at it, should I check the valves or is it a waste of time. Also, I'm assuming the clearances in the service manual are for a cold engine. Am I correct?
Thanks
vossy
I wouldn't bother checking the valves if it has only 400 miles.
I'm sure they are checked cold.
"Life's short" "Ride More"
EEL
Dont bother checking the valves. they will change when everything breaks in. Just do the belts and move on.
gr1976
Thanks everyone...you confirmed what I was thinking (and hoping)
