February 24, 2025, 12:05:37 AM *
Author Topic: Will this fit?  (Read 2044 times)
GoTeamV
Boosh!
« on: February 15, 2011, 05:56:07 PM »
http://cgi.ebay.com/ebaymotors/DUCATI-MONSTER-M-900-REAR-SHOCK-SUSPENSION-LINKAGE-_W0QQcmdZViewItemQQhashZitem3364f9c533QQitemZ220737422643QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_2930wt_1165
http://cgi.ebay.com/ebaymotors/Ducati-Monster-S2R-1000-Rear-Mono-Shock-_W0QQcmdZViewItemQQhashZitem4aa8376332QQitemZ320649782066QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_2385wt_1165
Will either of these fit on my 2003 Monster 620?  Because they were on larger bikes they should have a stiffer spring correct?
Thanks in advance for your help.
Dorothy Mantooth is a saint!!
Roaduser
will be back on the road june 16
02 m800 with extras
« Reply #1 on: February 15, 2011, 06:55:53 PM »
not necessarily stiffer springs on those, but they are progressive springs and they are generally crap. but for spring rates check out this post http://www.ducatimonsterforum.org/index.php?topic=39242.0
best option, and possibly even cheaper than the auctions u are looking at there is to simply replace the spring on your existing shock unit. you'll have to do your own research but i imagine you would get a new spring at the correct weight for you and your bike with your riding conditions for about $100. traxxion and gpsuspension come to mind first for me.
if u want to upgrade the shock unit there are many latter model monster and sbk shock units that will bolt onto your bike, but to get the best from them they will prob need a re-spring too. do a search and you'll find many threads with the options and examples og what ppl have used.
for an example i picked up a 749s (same as 999) 3way adjustable showa with the height adjustable link rod attached for $65. add a spring and i have a rear shock unit that is more than adequate for whatever road use i could possibly throw at it.
good luck, Cheers Clint
« Reply #2 on: February 15, 2011, 08:35:20 PM »
Will not fit your bike.
Same as what your bike came with.
GoTeamV
Boosh!
« Reply #3 on: February 16, 2011, 11:59:05 AM »
Would a 2008 Ducati Monster 1000S S2R rear shock absorber fit?
thought
Everyone needs a
« Reply #4 on: February 16, 2011, 12:19:34 PM »
i just had to be the one that tossed in the gratuitous "that's what she said"  haha
'10 SFS 1098
'11 M796 ABS - Sold
'05 SV650N - Sold
« Reply #5 on: February 16, 2011, 01:20:36 PM »
Per Ducati parts catalogues:
'03 620 - 365.2.045.1A Shock absorber
'07 S2R1k - 365.2.045.1A Shock absorber
So, same as what you've got.
Look for a shock from an '01 or '02 Monster S4, that will bolt right in and be an improvement.
It still came with the crappy progressive spring.
Depending on your weight, you may need a different spring.
Enjoying the ride
« Reply #6 on: January 15, 2013, 09:57:18 AM »
from a 749 . ..  to fit a 2005 M620
Plug 'n' Play?
or will this, also fit plug 'n play
