February 21, 2025, 10:24:47 AM *
News: Please Help
Author Topic: Am I really stupid? removing belt covers on 1100  (Read 1801 times)
Frustration
Insignificant Other
pezcyclingnews.com
« on: February 15, 2011, 07:23:09 PM »
I reskinned the bike, changed rear sets, swapped the oil cooler side panels...
I cant get the upper belt cover out of the frame...  It just wont budge.  The lower was obviously no problem, but ...
Anyone else as dumb as me?
Do I have to pull the tank and lift it out?
"I try to control baaat sometimes fast josta appen enyway"... VR46
zarn02
« Reply #1 on: February 15, 2011, 07:37:00 PM »
I helped a friend change belts a bit back, and remember the vertical cover being a huge pain in the ass.
Don't remember if there was any sort of special trick to the operation, but I know it required patience and harsh language.
rosstermyer
M1100S
« Reply #2 on: February 15, 2011, 08:26:12 PM »
take a microfiber rag and put it on the pretty side of the cover (if you are removing carbon ones) and just rip the sonuvapregnant dog out.  i had hell getting my carbon ones out, but with some good yanking it finally came out, but i scratched the clear on mine a little hence the microfiber recommendation.
Frustration
Insignificant Other
pezcyclingnews.com
« Reply #3 on: February 16, 2011, 07:41:15 AM »
Gulp!
« Reply #4 on: February 16, 2011, 10:19:04 AM »
take it out through the top
Frustration
Insignificant Other
pezcyclingnews.com
« Reply #5 on: February 16, 2011, 02:17:39 PM »
Even with the tank covers off, it wont coe out the top...
zarn02
« Reply #6 on: February 16, 2011, 02:23:34 PM »
Have you lifted/removed the tank itself?
Frustration
Insignificant Other
pezcyclingnews.com
« Reply #7 on: February 16, 2011, 05:11:53 PM »
Was hoping someone had a certain special twist that would keep me from doing that...
probably the next stop though.  Alternately I could dremel a small bit away from a couple of spots of the covers...  It's a small margin keeping em in and the parts that I would hit would be pretty hard to see...
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #8 on: February 16, 2011, 05:24:02 PM »
Fuel tank has got to go unless you wanna trash your belt cover.  Its not that hard: One allen bolt under the seat one more  bolt on either the left or right side support.  You dont need to completely remove the tank - just lift it up and away to the left to give you the room you need to get the belt cover out.
Really, its not that hard.
« Last Edit: February 16, 2011, 05:32:43 PM by ungeheuer » Logged
