How to fix your broken horn switch
Started by Timmy Tucker, February 16, 2011, 10:58:01 AM
Timmy Tucker
If you've ever dropped your bike, chances are you now have a stuck horn switch. Instead of forking out $200+ for new oem switchgear or trying to fit an aftermarket piece, in 20 minutes you can repair the one you have. I realize that some people are hesitant to work on anything electric, but this is probably one of the easiest repairs you can do. This can actually be done without unhooking the wiring connector from the bike (which is a bit of a pain), I removed it to make it easier to take pics. Also have a way to keep up with the tiny parts. The only tool you should need is a #1 phillips screwdriver. You may also want a second set of hands to hold the top half of the switch unit out of the way while you are working.
Caveat: The pics are from a '99 750. Your bike may differ.
1. First you need to remove the switch housing from the bike. Sorry, no pic of this step. It's just 2 phillips screws in the underside of the unit.
2. Here's what you will be looking at. Remove the screw circled in red and the plate it's holding down to gain access to the lower switches.
3. Next, remove the 2 screws circled in red and the turn signal switch will come out in 1 piece as pictured below. Do not remove the gold screw in the center, it's not necessary. Pay attention to how the turn signal lever interlocks with the white plastic part of the switch. This will be important during reassembly.
This comes out as one piece. Notice the detent at the end of the lever:
4. Here's the bits you're looking for. Loosen the screw circled in red 2-3 turns, there's no need to take it out. Simply rotate the switch back where it goes with a screwdriver. Tighten screw back up pretty snug, but be sure not to strip it out.
5. Here's the end result.
6. Re-assembly is simply these steps in reverse. Again, make sure you keep track of what goes where as some of the screws are different sizes. The only thing to watch for is installation of the turn signal switch. There is a detent in the end of the turn signal switch lever (you can see it in the 2nd pic for step 3). There is a corresponding slot and ball bearing in the white piece circled in red below. Just like making sexy time, be sure you place tab A into slot B. If you don't the turn signals won't work correctly.
There you go. If you have any questions or problems, feel free to ask away.
1999 M750 - "Piggy"
2007 S4RS
live2ride
just a note.  i fixed this on my bike some time ago, then had to repeat it again in a month.  i realized the screw holding the piece you moved between picture 4 and picture 5 (aka the button contact switch) wasn't holding it down well enough.  I decided to shove some pieces of electrical tape between the blue and red wire in pic 5 so the button cannot be pushed back.
Timmy Tucker
Quote from: live2ride on February 27, 2011, 02:06:45 AM
That crossed my mind, and I actually made a plastic shim to put in there, but in the end I decided against it. I was more concerned that permanent damage to the switchgear might occur if it whacked the tank hard again. I'd rather have to take it apart again than buy a $220 switch. Electrical tape seems like a safe bet since it would give with enough force. That said, it's been over a month since I fixed it and haven't experienced any unwanted movement from the switch at all.
1999 M750 - "Piggy"
2007 S4RS
mmarell
I can actually confirm the procedure!
On my way to the TT in Assen, The Netherlands, some a-hole tried nearly pushed me of the road while trying to overtake a truck (didn't see coming on the left lane).
I honked so violently that the switch got stuck in the process  [laugh]
I had to stop and disconnect the leads to the horn, for the last couple of the kilometers to the campsite [moto]
Often wrong, never unsure...
Ducatamount
Thanks,I checked this out before fixing mine (2001 M900S) and my switch was the same.I also did the folded wad of electrical tape,hopefully it won't happen again.I would just add that there is a little node on the bottom half of the assembly that has to fit in a hole on the handlebars when fitting the two halves back together.
half fast
same thing happened to my bike, the screw wouldnt hold it in place anymore, so i just extended the nub by adding a few dabs of solder on it.
patrickmccabe
great write up on this problem... my horn had not worked for years;
to be honest it scared me once I got it working. I used a chunk of
rubber to help  hold it in place.
Thank you!!!
hankrecor
This post was exactly what I was looking for and needed to fix my same problem.
Thank you for taking the time to document the process and clearly with noted photos.
Much appreciated.
Hank
2001 M750
stonemaster
apparently this must be a prevalent issue, I have problems with my horn, will definitely try this out, thanx
jduke
I had the same problem, I owe Timmy Tucker a cold beer or three, THANKS!!
When I first tightened the screw I tested it before buttoning everything up. I noticed the switch moved so I tightened it up some more but it still didn't feel solid.
I pushed the switch from the inside pretty hard and felt it snap into place. I almost thought I had pushed it completely out of the housing, but didn't. I tightened the screw and everything is solid.
I might be proved wrong after using it a few times but I feel you guys didn't push the switch from the inside hard enough to snap it back into place.
But no matter what, like live2ride said, this fix is a hell of a lot cheaper than a $220+ switch...
SaintP
Hi/Lo Beam button in upper half of same unit sticks in Hi position. With a little fiddling will unstick but not something that can be done while riding. Any suggestions as to how to repair?
jduke
Easy enough to take apart and look for anything loose or interfering with switch. Lube it and work it while apart and you'll probably fix it.
