S2R1000 20KLM service
Started by Two dogs, February 18, 2011, 01:05:51 PM
Two dogs
Can some one please  direct me to a link on the complete list of checks and replacement items
I must perform on my bike for DIY for the 20 000 klm /12 000 Mile service.
2006 S2R 1000.
It has full Arrow /Rapid bike ECU piggyback/Rapid bike Oxygen sensor emulator/ Open air box with K&N
Other than consumables belts and checking valves filters etc is there any PC work needed
or professional workshop secret alchemy   [laugh]  ?
Cheers
Here's a good start:
Valve adjust
Oil and Filter change, Screen clean
Hydraulic System, flush & bleed
Fuel Filter change, tank clean
T/B Sync
Steering head bearings, adjust
Belt Change
Spark Plug Change
Lube cables
General Checkover
Headlight
Taillight
Turn signals
Brake Light
Throttle function
Clutch function, fluid level
Front brake function, fluid level
Rear brake function, fluid level
Tire pressures
Chain Tension
Front brake pads
Rear brake pads
Air Filter clean
JEFF_H
there's a list in the owners manual
yuo can download one here-
http://ducati.com/services/maintenance/index.do
