February 12, 2025, 02:56:13 AM *
Pages: [1] 2   Go Down
Author Topic: Steering Damper side Mount Kit for M1100s?  (Read 5434 times)
scooterd145
« on: March 03, 2011, 02:00:15 PM »
Anyone know of someone who makes/sells these? I hate to spend $700 on something that can be made WAY cheaper if I only had a mount kit?
danaid
« Reply #1 on: March 03, 2011, 07:05:23 PM »
Search button, sponsor sites  coffee
11' 1198SP  Black
09' 1100S    Red
OBNOXS
« Reply #2 on: March 03, 2011, 07:21:55 PM »
You may want to look into the Bitubo setup. It's not designed for the newer Monsters, but it's a pretty universal design.
http://bellissimoto.com/BituboDampers.html
I wouldn't mind something that would fit below the triple like this:
http://www.motowheels.com/italian/myProducts.cfm?parentcategoryid=1204|Monster&productID=5412&showDetail=1&categoryID=126|Monster%20Suspension&vendoridtodisplay=0&filterFor=&collection=1204|Monster
I emailed Motowheels, but they didn't have anything similar that would fit the new monsters Undecided
« Last Edit: March 03, 2011, 07:25:50 PM by OBNOXS » Logged
« Reply #3 on: March 03, 2011, 09:58:49 PM »
the problem with kits designed for older monsters is the frame tube diameter. the new Monster is larger. so the mounts won't work on them.
once someone builds the correct diameter mount for the side mount I'd be interested
DoWorkSon
« Reply #4 on: March 03, 2011, 11:05:11 PM »
I have a side mount ohlins setup for my 696 which works really well. I had to buy a new fork clamp when I installed the sbk forks but the frame bracket fits perfectly.
2009 M696--SOLD
BellissiMoto
« Reply #5 on: March 04, 2011, 05:20:14 AM »
I don't know of any side mount damper kits available for the new monsters, though Im sure it can be done (I don't see why the one for the older monsters couldn't be modified slightly by your local machine shop to make it work if that is what you really want).
But why spend $700?
On that note, why get a side mount rather than a top mount - http://bellissimoto.com/BituboDampers.html retail for a top mount is only $525 and thats before your 10% forum member discount, plus they are in stock and can ship right away.
dennisd
« Reply #6 on: March 04, 2011, 06:21:38 AM »
I need the side mount also.  I have bar risers on my M1100 so a top mount won't work.  Since I put OZ Racing wheels on, either I am giving unintended input to the bars when riding aggressively through turns or the bike is picking up pavement imperfections which is unsettling the bike slightly.  Yes, I'm using proper riding technique.  It is not a serious amount, the bike just doesn't feel quite as planted as I'd like.  I'd like to stop it and I think a damper would help.
« Reply #7 on: March 04, 2011, 11:27:03 AM »
But why spend $700?
I'm running clipons and don't have the riser anymore. the top mounts wont' work
DoWorkSon -Can you post pics and parts list and pricing
DoWorkSon
« Reply #8 on: March 04, 2011, 11:43:26 AM »
Here is an old pic with it installed..
I know it looks really long in that pic and like it would get in the way, but that is because the wheel is turned. When riding, it is shorter and not even an issue...
I am not sure of the part#. I looked on it, and could not see one. I bought it from a board member over a year ago for like $150. I will try to look around and see if I can find the box or manual for it.
2009 M696--SOLD
« Reply #9 on: March 04, 2011, 11:58:29 AM »
ok you tied it to the vertical pipe. was wondering how you did that.
maybe move the mount back to one of the x pipes and see if it sits better cause it looks like it would jam into your knee on left tight turns (parking lot) but also on a tank slapper that would hurt.
I do like it, and you suck for getting that deal Wink
DoWorkSon
« Reply #10 on: March 04, 2011, 02:02:11 PM »
Honestly, with the angle that it is at, even when the wheel is turned fully, it doesn't even come close to my knee. Not sure if it's the new rearsets or what, but It doesn't come close.
2009 M696--SOLD
BCMonster
« Reply #11 on: March 04, 2011, 02:28:50 PM »
I have the risers and just added the DP damper. No big deal to build a couple of spacers for where the mount attaches over the ignition.
JEFF_H
« Reply #12 on: March 04, 2011, 04:35:25 PM »
Kyle Racing makes mounts....might be worth checking there
asherrick
« Reply #13 on: March 04, 2011, 05:03:42 PM »
Here's the link:
http://www.shop.kyleusa.com/product.sc?productId=237&categoryId=-1
'09 M1100s
mattc7
« Reply #14 on: March 06, 2011, 04:45:37 AM »
I run a top mount bitubo off an 848.  had to modify one bracket by grinding and drilling a new hole because the ignition bolts are closer on the 1100 than the 848.   but its top mount so I don't worry about it ib event of fall.  also had to leave a tiny bit of fork on top of the triple and had a 50mm fork clamp rather than supplied 53.
also. I have seen a sidemount damper through a leg.  it isn't pretty
I got my bitubo from Randy 2 years agoband it still works flawlessly.
Pages: [1] 2   Go Up
