February 12, 2025, 02:40:03 AM
Radial Masters for a S2R800
Topic: Radial Masters for a S2R800 (Read 1921 times)
TitanMonsterS4R
March 06, 2011, 10:30:25 AM »
Brakes, suspension, rear shock, front forks, taillight, headlight and signals have all been changed from stock and working perfectly. I'd love to upgrade to radial master cyclinders. Anyone have a suggestion for a brake/clutch radial cyclinder kit? Would like something less than $300.00 per. Even better would be a deal for the combo.
Really like these but this is is after very little research -
http://www.motostrano.com/brrcs15macy.html
Thanks
Punx Clever
Re: Radial Masters for a S2R800
March 06, 2011, 10:46:43 AM »
Look for take-offs from a SBK... I have the masters from a 999r on my s2r1000. Both sides with aftermarket levers was less than 300 easy. I think somewhere in the 200 range actually. Plus, the reservoirs look sweet and low profile.
2008 S2R 1000 - Archangel
The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over. - HST
supertjeduc
March 06, 2011, 10:48:40 AM »
Think this is the best buy
Had them all (brembo magura, etc)
http://cgi.ebay.de/Pompa-freno-19-frizione-16-radiale-DISCACCIATI-kit-/330455727086?pt=Ricambi_e_Accessori_Moto&hash=item4cf0b23bee
xcaptainxbloodx
March 06, 2011, 02:14:51 PM »
http://cgi.ebay.com/ebaymotors/DUCATI-848-1098-08-FRONT-BRAKE-MASTER-CYLINDER-LEVER-_W0QQcmdZViewItemQQhashZitem45f90076fbQQitemZ300530300667QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_2845wt_1075
http://cgi.ebay.com/ebaymotors/DUCATI-oem-CLUTCH-MASTER-CYLINDER-848-1098-1198-ALL-_W0QQcmdZViewItemQQhashZitem1c19aeacabQQitemZ120689962155QQptZMotorcyclesQ5fPartsQ5fAccessories#ht_500wt_847
probably better deals out there but thats ~$300 for the PAIR, plenty of cash left over for a set of levers and maybe some reservoirs.
March 06, 2011, 03:27:54 PM »
Quote from: MadDuc 20/20 on March 06, 2011, 10:30:25 AM
Thanks
Just so you know, the RCS that you linked to will only do the brake side and not the clutch. Also, that isn't the best piston size (15)for the set up that you've got on your bike. You'd want something a bit larger so you'd get both decent modulation and stopping power.
TitanMonsterS4R
March 06, 2011, 03:28:52 PM »
Quote from: DRKWNG on March 06, 2011, 03:27:54 PM
Thanks DW
S2R 800 '07
March 06, 2011, 03:44:22 PM »
Brembo RCS comes as 19mm brake master as well as a clutch master.
About a hundred $ less gets you a standard radial Brembo 19mm, but the RCS has the lever ratio adjustment and a brake light switch.
March 06, 2011, 03:47:33 PM »
The RCSs actually comes in multiple piston sizes and are tailor made to specific applications.
ajw85
March 07, 2011, 01:32:31 PM »
I have a 999 radial brake master on my bike with the big brakes.
I don't really ride it that hard so I don't notice much difference. I got both clutch and brake for <$200 off of ducati.ms.
Figure out how you're going to mount your brake lines before proceeding, as they are a pain in the butt. Expect to shell out some more cash for custom brake lines to do the job right.
TitanMonsterS4R
March 08, 2011, 06:55:07 AM »
Quote from: ajw85 on March 07, 2011, 01:32:31 PM
Will my stock brake lines work or will I need to get new ones with the new radials?
S2R 800 '07
March 08, 2011, 07:39:32 AM »
The banjo angles are different at both ends, so that's a
no
- sorry.
At the master the line(s) connect under and horizontal - banjo angle(s) depend on the chosen routing.
At the caliper they connect on top - meaning a ~90 degree banjo.
loves ze desmodromics.
March 08, 2011, 08:07:40 AM »
Easy fix available for the lines, though:
M1100 oem lines. You can find take offs on eBay. Hypermotard lines would work also but are longer.
supertjeduc
March 08, 2011, 12:01:33 PM »
You can use the om clutchline , but you must switch it upside down
TitanMonsterS4R
March 08, 2011, 12:38:42 PM »
I may have struck gold and didn't even know it.
SVR sold me some Goodridge lines in January that are a universal mount with NPT ends so I can fit the right banjo on there. He also threw in some extra banjo fittings with different angles and one brake light switcher banjo. Here's the link to what I purchased. Sorry for the noob question, just want to make sure I do it right.
http://picasaweb.google.com/SJRandolph/BrakeLines#
Last Edit: March 08, 2011, 01:58:32 PM by MadDuc 20/20
ajw85
Reply #14 on:
March 09, 2011, 06:44:06 AM »
Quote from: MadDuc 20/20 on March 08, 2011, 06:55:07 AM
Quote from: MadDuc 20/20 on March 08, 2011, 12:38:42 PM
You did strike gold. That will make running the hydraulic lines much easier.
I would post pictures of my set up but I am embarrassed to show how ghetto it is. Good luck and post pictures when you're done.
