Pep boys battery anyone?
Started by He Man, March 12, 2011, 09:29:58 AM
Anyone ever bought a pepboys branded battery? i bought a yuasa for my friend and everything minus the print on the battery itself is the same.  This is for my bike, which gets ridden pretty much everyday. My current battery wont start the bike anymore (left me stranded even though i charged it up just a few days before)
the pepboys battery is pretty much identical to the yuasa minus the actually print on the battery.
They are just a chinese copy.  Probably work find.
I get batteries from bikebatts.com.  They sell no-name AGM batteries for cheap CHEAP CHEAP.  I have one on my Elefant that's 6 years old now.  No problems.
Or use this:
bikebatts.com has them for cheep, but after shipping its the same price as pepboys.
I took the batt from the 1098, it reads 12.5v cold, and drops down to about 10volts durign cranking. It works fine so i think ill keep his until the batt starts getting really bad.
Is that the wet acid or AGM battery?
Quote from: ducatiz on March 12, 2011, 04:22:26 PM
AGM, i think after a certain year all ducati batts were yuasa AGMs.
After 99?  My 98 FE has a wet acid YB16AL-A2.
Either way, the bikebatts batteries are pretty good, I didn't know poopboys sold agm batteries!
Quote from: ducatiz on March 13, 2011, 12:07:01 AM
$54.99 at mine. After tax, you might as well just get it from them. 3 month warranty too. the packaging is identical to Yuasa. down to the instruction manual and the plastic foil seal that covers the batterys acid port prior to filling.
Filling?  That's not an agm then!
Quote from: ducatiz on March 13, 2011, 01:21:38 PM
The Yuasa is labeled as a AGM batt. You have to fill it to activate and then permanently cap it off. Its maintence free afterwords. The one your thinking about is regular batts where you can remove the cap and fill it as the acid begins to drop. Its just a difference of being activated at the factory, or consumer activated i think.
au contraire.
they get filled it's just all the acid is absorbed by the  mat.
Quote from: ducpainter on March 13, 2011, 01:38:29 PM
au contraire.
One of the features I like about that Yuasa.  Battery life starts the day it is activated.
Interesting.  Never seen an agm that you fill.
Quote from: ducatiz on March 13, 2011, 02:07:35 PM
Only because you always bought them pre-filled.
Most AGM batteries come pre filled including most Yuasa.  The YT12B-BS is an exception
it's pretty interesting nevertheless.  the whole idea of a sealed agm battery was that they are sealed at the factory OR SO I THOUGHT
i am going to go by poopboys near me and see what they have.. i need a big battery for the darmah
kui, which store did you go to?
