Ride Height Adjuster?
Started by csorin, March 12, 2011, 08:32:29 PM
csorin
Hey guys,
I took apart my rear end a couple weeks ago to replace the silver swingarm on my monster.  While in there, I noticed that my ride height rod might be adjustable.  Is this rod adjustable?  Does the amount of threads showing look safe?  Any guess on how much more room I have to raise the ride height?
Yes, that is an adjustable link.  I have no way of knowing how many threads are not showing so I can't answer your second question.   Do you know if that link is OEM or aftermarket?
csorin
Pretty sure it's aftermarket.  From what I've read on the forums, the 620's came with non-adjustable units.
Jarvicious
If you're rockin a 620, it's definitely aftermarket.  I just lengthened mine on my S2R and I don't think I had that many threads showing, but I don't think yours is a Ducati unit.  When I took the heim joint all the way out of the linkage rod, it probably had a good inch/inch and a quarter of threads on it, so if you wanted to raise the rear end on your bike, I'd say you have a good amount to play with.
One question though, does the 620 operate on the same upper rocker arm design that the S2/S4s do?  If so, you have to remember that there's a ratio and you don't have to add nearly as much length to the linkage rod as you want raise height.  I think someone mentioned 3:1, i.e.- 1/2 inch more length on the linkage rod, 1.5 inches ride height addition.
All the ST framed Monsters share the same linkage arm.
CDawg
I have a similar looking link on my S4RS.  OEM recommendation for mine is no more than 5 threads showing.
