Daytona (SPOILERS)
Started by Spidey, March 12, 2011, 09:38:23 PM
Cider
Cider
OT
#62
zooom
2010 KTM 990 SM-T
gm2
i think they definitely should have waited 'til after they go to a couple less duc friendly tracks.  but otherwise, conceptually, what's so wrong with this?  other series do exactly the same thing, through one means or another.
Like this is the racing, no?
Triple J
Quote from: gm2 on May 25, 2011, 01:58:05 PM
+1
My only complaint is they did it after only one dominant performance. It's no different than WSBK adding weight to the 1098R for the 4th race of the season in 2008.
derby
Quote from: Triple J on May 25, 2011, 03:47:46 PM
+1
...except there's an actual formula in the worldsbk regulations that determines when and how much weight or air restrictor is added/removed.
-- derby
'07 Suz GSX-R750
Triple J
#67
Quote from: derby on May 25, 2011, 06:41:00 PM
I take it there's no formula or rule provision for this?
Spidey
Quote from: Triple J on May 25, 2011, 09:47:04 PM
If 3(Disalvo) > 3(restoffield), then +5D & -5I4.
Formula?
How can you be capricious and vindictive if you've got to use a Formula?
gm2
wonder what would have happened if disalvo were on a buell.  ...an 1800cc buell, obviously.
