February 12, 2025, 05:57:50 AM
Rear shock application
Topic: Rear shock application (Read 2005 times)
pcv57
March 16, 2011, 02:41:37 PM »
I recently purchased a used Penske shock for my s2r1000 but it came from an M900. All the mounting seems the same except I learned the Penske is about 1 inch longer than the stock Sachs shock. I know this will change the ride height but I'm wondering if it would be so much so that it will negatively affect the the stability and handling. Does anyone have any suggestions?
Cloner
Nah...I ain't no stinkin'
....because a mind is a terrible thing......
Re: Rear shock application
March 16, 2011, 03:21:24 PM »
With most Ducatis I've ridden or been around, increased ride height is a welcomed enhancement. It transfers a bit of weight to the front wheel (which in most Ducatis is beneficial) and increases ground clearance.
I don't know much about Monsters, but I'd say as long as the saddle height is still comfortable you ought to give it a try.
Never appeal to a man's "better nature." He may not have one. Invoking his self-interest gives you more leverage. R.A. Heinlein
'64 Ducati Monza 250
'00 Aprilia RSV Mille
'03 Ducati 800 SS (race bike)
'04 KTM 450 EXC
hackers2r
March 16, 2011, 03:44:32 PM »
Which Penske is it? Can the length be adjusted? On all of their current models, seems like length is adjustable. And if it's adjusted all the way in already, maybe you can get a different length eyelet from Penske.
Last Edit: March 16, 2011, 03:59:49 PM by hackers2r
pcv57
March 16, 2011, 04:11:04 PM »
It's the 8983 double clicker with the remote reservoir. I spoke to Penske and they told me that it's an inch longer and that to make it "right" for my bike it would cost $450. I think he said it would need a new body. It is adjustable from 12 1/8 to 12 9/16 eye to eye.
hackers2r
March 16, 2011, 04:18:41 PM »
Well if it's got the same stroke as what's supposed to be on there, I'd be tempted to just use it. Are you flat-footing the ground now? Only other limitation I can think of is exhaust clearance with the swingarm and I don't think 1" is gonna be a problem.
hackers2r
March 16, 2011, 04:23:25 PM »
Also, to compensate for the longer shock, you could check the ride height adjuster to see if you can bring that in.
pcv57
March 16, 2011, 04:26:56 PM »
I'm tall enough so I'm not worried about reaching the ground but how does stroke affect the ride and handling? Also, does anyone know the dimensions of the stock Sachs unit from eye to eye?
hackers2r
March 16, 2011, 04:33:12 PM »
Stock Sachs on the S2R is 305 mm = 12.007 in. If you can adjust that Penske to 12 1/8, you're only 1/8 over the stock. Shouldn't be a problem at all!
March 16, 2011, 04:34:16 PM »
Quote from: hackers2r on March 16, 2011, 04:33:12 PM
+1
pcv57
March 16, 2011, 04:36:40 PM »
OK, I'm starting to feel better about it. Now how about the stroke issue? What is it and what does it do?
hackers2r
March 16, 2011, 04:37:05 PM »
Also, the longer the stroke, the more room for damping. But seeing as it came from a Monster already, don't think there'll be a difference in stroke.
pcv57
March 16, 2011, 04:41:55 PM »
Many thanks, guys. I'll get it in and report back. Of course then it'll be the ominous task of setting the sag and dialing in the new shock. I think I'll leave that to a professional
Cheers
bikepilot
March 17, 2011, 04:36:21 AM »
Being only an 1/8th off shouldn't be too bad. Do be aware that it will raise the bike more than 1/8th. You can use an adjustable link to put the height back to stock or set it as you need to (if your bike didn't come with an adjustable link as standard). A link from a 748 should be about the same as your stocker, but adjustable with a little room to go higher or lower. a 749/999 link should be about 10mm shorter IIRC.
Last Edit: March 17, 2011, 09:19:40 AM by bikepilot
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
