February 14, 2025, 10:08:23 AM *
Author Topic: Replacing front turn signals on 07 s4r  (Read 1752 times)
DuctheMonster
« on: March 19, 2011, 02:37:18 AM »
So I just chopped the frame and put on an integrated rear brake light and turn signals. I'm about to take of the stock front signals and put on the ones I ordered, but I just wanted to see if anyone knew how to specifically remove the front signals, since with the back ones I never really removed them since I just took off the whole beer rack. Has anyone already done this and can give me a general idea of what to do? Thanks for the input I'll try and put some pics up later of the finished product!
S2R 800 '07
« Reply #1 on: March 19, 2011, 06:43:31 AM »
Unbolt. Disconnect.  cheeky
There's an allen bolt into the stalk, from inside the headlight/signal light bracket.
If you can't reach it - remove headlight first.
Disconnect two pairs of wires (bullet type)
If you have LED signal lights - you might need resistors to slow down flash rate.
askene
« Reply #2 on: March 19, 2011, 07:36:25 AM »
^^^^ What he said.  It's super easy
I replaced mine with oberon LED signals a few weeks ago.  The whole thing took an evening after work.  I ended up re-mounting them onto the headlight bucket's bolt holes instead of where the stock ones were to clear the faring.  Someone else had a nice thread on doing the same thing with lots of dismantling pictures, but I can't find it now.
2007 S2R 1000
1999 SV650
« Reply #3 on: March 19, 2011, 09:22:35 AM »
just take a look at it and you'll see how simple it is, if you cant figure it out on your own, step away from the bike and put the blow torch down!!!
however, do note that if you are using the front faring, the blinkers may not clear the fairing since most aftermarket blinkers are shorter than the OEM front blinkers.
