February 12, 2025, 05:00:15 AM *
Author Topic: Removing baffles in Boom Tubes?  (Read 1594 times)
mickb
« on: March 19, 2011, 05:43:42 AM »
I'm trying to remove them, with the intention of putting another set in, but I can't see how to get them out? There's no lip as per termi baffles to grip, and as the pipe has a 90 degree bend, you can't push out from the back.
I'm waiting for Mark to respond, but just wondered if anyone had done this?
thanks.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
Often wrong. Never in doubt.
« Reply #1 on: March 19, 2011, 06:03:04 AM »
Are they held in place with a circlip?
mickb
« Reply #2 on: March 19, 2011, 06:12:19 AM »
Hi Unge,
No, they were rivetted to the outer pipe, and I've drilled these out. I'm guessing its because they're a tight fit, and there's nothing to be able to grip to either push or pull.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #3 on: March 19, 2011, 06:17:04 AM »
Hmm... dunno...
This..
Plus this..
 Huh?
Disclaimer: Dont blame me  Wink.
mickb
« Reply #4 on: March 19, 2011, 06:21:33 AM »
worth considering....  Smiley
cheers.
« Reply #5 on: March 19, 2011, 06:21:54 AM »
maybe this?
uglyducky
something, words, clever . . .
one way to do this is we can all get naked . . .
« Reply #6 on: March 19, 2011, 06:29:13 AM »
Hmm... dunno...
This..
Plus this..
 Huh?
hahahaha
2001 996 Biposto - (sold)
mickb
« Reply #7 on: March 24, 2011, 11:05:42 AM »
Still struggling with this, tried a slide-hammer with a hook into one of the slots inside, but I can't get it to move even a fraction  Huh?
mattc7
« Reply #8 on: March 24, 2011, 12:07:02 PM »
Heat?
uglyducky
« Reply #9 on: March 24, 2011, 12:19:02 PM »
it's probably hopeless . . . sell them to me  Grin
Slow Guy
« Reply #10 on: March 24, 2011, 01:10:31 PM »
cutting torch and hammer  Evil
« Reply #11 on: March 24, 2011, 01:48:53 PM »
Just from looking at mine, I'd wager they're held in by the same rivet that holds the tips on.
ɹǝʌO d∩ uıɐןɐɹʇsn∀
« Reply #12 on: March 24, 2011, 04:26:33 PM »
What advice did Mark give you??
mickb
« Reply #13 on: March 25, 2011, 06:25:39 AM »
I've drilled out both rivets, there's nothing holding it in there now apart from friction!
I've been able to finally remove one of the baffles, using a slide hammer, the other is refusing to budge.
Mark has suggested using a hacksaw blade to cut through the baffle, but as its T304 steel, this won't be easy.
I'm going to try taking to a garage /mechanic with the hope that using heat from a welding torch expands the outer pipe enough to pull the baffle....
« Reply #14 on: March 25, 2011, 06:55:53 AM »
It may be time for chemical warfare.
http://www.jeepforum.com/forum/f11/atf-acetone-vs-pb-blaster-others-766271/
