February 10, 2025, 03:47:26 AM *
Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Radical Ducati now in the US  (Read 46889 times)
TAftonomos
is without a monster :(
« Reply #45 on: April 19, 2011, 06:50:51 PM »
Looks pretty good.  Nose looks a bit low, like it will hit the fender under full compression.  Might just be the angle though.
Thanks for the pic(s)!
mia monster
« Reply #46 on: April 19, 2011, 08:02:00 PM »
      Yeah you would need to bore the engine cases, or the bottom of the frame can be modded to be more like a 999 style. This way you would not need to touch your engine. The frame can be made to fit your engine and swingarm when ordered, but I think its easier to bore the cases.
       They also have Aluminum Frames for Monster http://www.radicalducati.com/index.php?page=diciembre-2006
mia monster
« Reply #47 on: April 19, 2011, 08:05:14 PM »
      And the front fairing is not in the right place yet, there are a lot of small styling changes done to the nose and tail before the bike is done.
loves ze desmodromics.
« Reply #48 on: April 20, 2011, 07:05:56 AM »
you let me know a place that bores cases "easily" to change the location of the swingarm pivot hole on the ellipse, high-to-low or vice-versa, and I'll be sending them an empty set of crankcases "tomorrow" (and by tomorrow I mean the very day i finish removing all the "innards", and such).
mia monster
« Reply #49 on: April 20, 2011, 05:38:50 PM »
      Well I said easier not easily, and anyone with a Bridgeport should be able to mill the cases. Theres probably a dozen machine shop in my area that can do it, so when you get that bottom end apart let me know and ill give you some names.
TAftonomos
« Reply #50 on: April 20, 2011, 06:15:27 PM »
You are planning on mocking the engine up/marking it in the actual frame....correct?
« Reply #51 on: April 21, 2011, 07:36:08 AM »
yes - so its both up/down and forward/backward correct.
Punx Clever
« Reply #52 on: April 22, 2011, 08:36:24 PM »
Methinks it would be easier to mod the frame.  There are a lot more people with welders than there are people with mills... and you don't have to gut the engine to do it.
2008 S2R 1000 - Archangel
mia monster
« Reply #53 on: April 23, 2011, 12:53:14 PM »
      Yes alot of people welders and alot of people can weld, but the frame is aluminum and when aluminum is welded it gets soft so the more times you cut/weld/mod the frame the softer the alloy gets. So again its up to you but ether way milling the cases or re-heat treating the frame its not easy, but that all the fun of custom building a bike Grin
Turf
Awesome > Logic
« Reply #54 on: May 23, 2011, 03:14:31 AM »
Was excited to see that I got an email with some new pics and telling me that my radical stuff should be here this week   Grin
671M900
« Reply #55 on: May 23, 2011, 03:39:51 AM »
I love it, but where's the exhaust?
671ducati.wordpress.com Record of Progress!
« Reply #56 on: May 23, 2011, 04:43:07 AM »
And oil cooler lines. Clearly a work in progress.
671M900
« Reply #57 on: May 23, 2011, 04:49:10 AM »
And throttle... haha.. Still, looks great!
sgollapalle
« Reply #58 on: May 23, 2011, 05:08:49 AM »
And cables to the front brakes  Wink
'11 M-696
mia monster
« Reply #59 on: May 23, 2011, 07:00:10 AM »
And paint, and powdercoat, and wiring harness, and seat, and connected water cooler lines. its in its finall moc-up so we can pick colours and fab the exhaust. It should be finshed in a few weeks Grin
« Last Edit: May 23, 2011, 07:07:50 AM by mia monster » Logged
Pages: 1 2 3 [4] 5 6 7   Go Up
