December 24, 2024, 05:47:47 AM
Honda gearbox
Topic: Honda gearbox (Read 3611 times)
gm2
Honda gearbox
March 22, 2011, 01:16:02 PM »
was discussed off and on a bunch in
Sepang 2 test
but maybe needs it's own thread finally.
Here's a marginally scientific look at it.. interesting, as usual:
http://motomatters.com/analysis/2011/03/19/honda_s_magic_gearbox_worth_a_few_hundre.html
Like this is the racing, no?
Triple J
Re: Honda gearbox
March 22, 2011, 01:29:03 PM »
That's really interesting. Looks like Ducati needs to get to work on their gearbox!
Re: Honda gearbox
March 22, 2011, 01:55:45 PM »
Quote from: Triple J on March 22, 2011, 01:29:03 PM
Along with
still
trying to tame the slithering beast.
swampduc
'99 996, '07 S2R1000,'08 1098s, '12 1199s
Re: Honda gearbox
March 22, 2011, 05:04:48 PM »
Conservative estimates at .2 seconds/lap! Very impressive, HRC.
Respeta mi autoridad!
OT
Still Sweeping.....
Re: Honda gearbox
March 22, 2011, 05:24:45 PM »
"...based on or very similar to the Xtrac Instantaneous Gearshift System, which allows two gears to be engaged simultaneously, while driving only one."
I'm no tranny expert, but one gear being driven while two are engaged sounds a lot like an 'automatic' transmission where hydraulic/mechanical systems do the job of the driver (using a clutch and gearshift lever)...?
zarn02
Re: Honda gearbox
March 23, 2011, 12:39:19 PM »
That's an interesting read.
And I'm not sure what the FIM says about it, but I would assume it's still a "manual" so long as the rider has to use the lever to shift, the clutch off the line, and so forth.
Last Edit: March 25, 2011, 06:46:29 PM by zarn02
The best kind of whore is a
Re: Honda gearbox
March 29, 2011, 04:07:43 AM »
+1
racing sure does drive innovation.
That's cool
Cider
Re: Honda gearbox
April 03, 2011, 07:42:24 AM »
Here's a pretty good guess of what technology Honda is using:
http://www.sportrider.com/news/146_1104_honda_secret_motogp_rc212v_transmission_revealed/index.html
Scooter-Trash
Re: Honda gearbox
April 03, 2011, 02:26:44 PM »
Nice detective work
Mind you, the whole point of disallowing double clutch systems was to keep costs down. Ironically, systems like this one are now becoming the system on choice on vehicles that used to use dual clutch systems (and it's just as expensive). And without the ability to handle downshifts under power or upshifts under engine breaking, I see an issue with using this on the street...
I wish Dorna would make up it's mind and either make an "unlimited" (except perhaps for weight, displacement and engine type) class where anything else goes.
Still, kudos to Honda for stretching the rules
Re: Honda gearbox
April 03, 2011, 03:18:38 PM »
Odd that they're patenting racing equipment.
But back in the day when I was at Yamaha R&D, I saw lots of wacky stuff that Honda patented.
This looks a lot like a revision of a Hodaka trans from 40 years ago.
Cider
Re: Honda gearbox
April 03, 2011, 03:24:30 PM »
Quote from: Drunken Monkey on April 03, 2011, 02:26:44 PM
Maybe that says something about eliminating specific technologies for the reason of cost? Teams tend to adopt even more expensive alternatives.
Scooter-Trash
Re: Honda gearbox
April 03, 2011, 08:23:11 PM »
Yeah, there's a story from the '70s that when the AMA outlawed aluminum swing-arms due to the cost, some team simply went out and built a titanium swingarm
OT
Still Sweeping.....
Re: Honda gearbox
April 04, 2011, 07:35:33 AM »
Someone on another list wondered if the Honda design makes it difficult/nearly impossible to push start after a crash...?
zooom
Re: Honda gearbox
April 04, 2011, 07:45:20 AM »
Quote from: OT on April 04, 2011, 07:35:33 AM
there was a quote somewhere that said it does require 2 people to push start it after shut-off in that kind of event...
http://www.superbikeplanet.com/2011/Apr/110403rydernotes2.htm
Quote
Only one marshal tried to push start XXXXX, the rest ran back to their post after XXXXX had departed. Now the Honda's clutch,
for whatever reason, requires a push start from two people. HRC know this but obviously see compensating advantages.
modified for to take names out to not spoil anything....
2010 KTM 990 SM-T
Scooter-Trash
Re: Honda gearbox
Reply #14 on:
April 04, 2011, 08:32:02 AM »
Yeah, the rider in question was
whining about
mentioning the need for "two pins to push", post-race
