New Truck & Ramp?
Started by dgm, March 26, 2011, 08:55:16 PM
justinrhenry
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
muskrat
I concur with previous statement.  Ramp needs to be wide enough so you can walk along side if you are pushing it or wide enough for both feet while riding it up.  The first time will scare you but after that it's a breeze.  A cheaper alternative may be buying a small utility trailer from craigslist if you have storage.  Or buy one of these http://www.sportutilitytrailers.com/LongChih/746TE-1TS76M.htm  There are tons of mods you can do to this trailer and it's really nice.  Got mine for $500 but sold it when I bought a truck again.  Another option is one from Harbor Freight http://www.harborfreight.com/1195-lb-capacity-48-inch-x-96-inch-heavy-duty-foldable-utility-trailer-with-12-inch-wheels-90154.html
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
Quote from: dgm on March 27, 2011, 08:12:12 AM
<snip>  I actually have a perfect spot just outside my garage that would almost put the bed of the truck level with my driveway... would be easy to load I think.  My concern then would be unloading/reloading once I got to the track.  I suppose I just need some practice doing it.  I happen to have a bunch of brand new ratcheting straps from my last truck, but someone mentioned not using the ratchet-type.  Why?
There's usually someone at the track willing to help unload and load.
The tendency is to over tighten with ratchet type straps. You don't have to bottom the suspension. They'll be fine IMO.
bikepilot
Ratchet straps are fine, just more fiddly/annoying than straps designed for securing a bike.  I use the answer pro taper tie-downs and like them quite a lot.  Wide, strong, fast and have a built-in soft-tie type thing.  I had these securing the wife's monster when I brought it home from Baltimore and it didn't budge (and plenty of pot-holes in b-more and DC to test them).
http://www.amazon.com/Pro-Taper-Tiedowns-Black/dp/B002YMV6XM
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
bikeguy57
Pitbull makes a nice removable wheel chock made for sportbikes with big rotors. I really like mine. Also recommend basic Ancra straps and a Canyon Dancer harness.
herm
i prefer the cam lock straps, partly for the reason DP mentioned...and a wheel chock (which I need to replace BTW....if anyone is wanting to get rid of one.)
No more Monster. But my Triumph Tiger 900 RP is wicked fun!
I've got one of these mounted in the bed of my Dakota, it's fantastic:
CCR Sport's Bed Buddy
Ancra tie downs
Diamondplate aluminum ramp from Industrial Metal Supply
booger
http://www.bikelug.net/index.html
This is a cool item. A bike trailer that collapses and fits inside the trunk of a car. I want one.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
geoffduc
I load bikes in the store van on a daily basis and never use ratchet straps only the cam lock type of strap plus a wheel chock like the baxley is a great help.
I see guys come into the store parking lot in vans and when they open the doors you can see that they've got ratchet straps on the front of the bike pulled down so hard that the front forks are bottoming out and occasionally there will be a blown seal thats why I personally don't like ratchet straps.
[coffee]
2015 scrambler FT
2009 monster 1100s
dgm
good advice and valid warning about the ratchet straps.  What about this from pitbull: http://www.pit-bull.com/trailer-restraint.shtml  ?
2009 696, Termi CF Pipes ECU Intake, Woodcraft Rearsets, Fender Elim, Shorty Pazzo Levers, CRG Lane Splitters, DP Low Seat, Powder Coated Bits, Speedymoto Frame Sliders, Rizoma Front Sliders, Rhinomoto Rear Sliders, Shorai Batt, Billet Oil Cap, iPhone Mount, LED Blinkers, Leggero Sprocket Cover, TPO Corsa Crankshaft Cover, Canister Delete/Euro Shroud, 14T Front Sprocket
Kopfjäger
Quote from: dgm on March 27, 2011, 11:27:27 AM
Those work great, but won't work in the bed of the Toyota. Your rear wheel will be partially on the tailgate.
dgm
Quote from: kopfjäger on March 27, 2011, 11:57:27 AM
True.  Good point.  It probably wouldn't be far enough onto the tailgate to mount this ON the tailgate, but far enough that it won't be mountable in the bed either.
Kopfjäger
Quote from: dgm on March 27, 2011, 12:00:10 PM
It might work now that I think about it, but would need to be mounted almost at the end of the bed. I have the Baxley under the front wheel, so that moves the bike back some. Without it (the Baxley) the pitbull may work. (?)
DW
I've always been curious, how is compressing a fork within its normal range of travel is supposed to blow a seal???  They aren't air shocks.  The spring tension has nothing to do with the damping fluid.  I also don't see how it could do anything to weaken the springs since there should be no way to compress them past a yield point.
As such, I am a huge fan of using ratcheting straps.  While I have never seen any damage due to overtightening a ratchet, I have seen plenty of camlock straps slip.  I've also seen an under tightened bike lose all strap tension when the truck hit a bump and the bike nearly fall over.
I tighten the straps down enough so that the fork will not compress any more when I throw my weight into it.  That way, if I hit bump, it does nothing.  No problems or dropped bikes so far.
There is a volume of air contained in the forks, and it's pressure increases the further the forks are compressed.
So, leaving them compressed beyond the normal riding position does put more stress on the seals.
Leaving them reasonably compressed ( I.E. not more than 1/2 travel) for a couple hours, no big deal.
Leaving them nearly bottomed out for week while going cross-country, not so good......
The point of contention of ratchet straps is you can easily overdo it.
Camlock tiedowns, it's a *lot* harder to overdo it.
There's significant quality differences on camlock tiedowns, the thin webbing of the cheaper ones make 'em more prone to slip or break.
I've been using Ancra tiedowns for 30+ years without a failure.
