New Truck & Ramp?
Started by dgm, March 26, 2011, 08:55:16 PM
dgm
Found a truck tonight that I'm strongly considering.  2010 Tacoma with 6ft bed, 5spd manual, 4X4.   I'd like to use it for taking my monster to track days, but have to admit that I've never owned a truck and a motorcycle at the same time, so I've never loaded a bike into a truck bed.  Looking for any advice on this in general, advice on ramps to purchase and/or advice specific to this particular truck.
thanks!
2009 696, Termi CF Pipes ECU Intake, Woodcraft Rearsets, Fender Elim, Shorty Pazzo Levers, CRG Lane Splitters, DP Low Seat, Powder Coated Bits, Speedymoto Frame Sliders, Rizoma Front Sliders, Rhinomoto Rear Sliders, Shorai Batt, Billet Oil Cap, iPhone Mount, LED Blinkers, Leggero Sprocket Cover, TPO Corsa Crankshaft Cover, Canister Delete/Euro Shroud, 14T Front Sprocket
herm
truck should be fine. make sure whatever ramps you choose don't have too steep an incline to them, or you will bottom out the bike..
No more Monster. But my Triumph Tiger 900 RP is wicked fun!
xcaptainxbloodx
the ramp doesn't matter so much as long as its designed to be a motorcycle ramp (the 50$ harbor freight ones are just fine). just back up so that your rear wheels are in a valley (edge of the driveway is my favorite) so you don't have to step up so high.
I HIGHLY recommend a sport chock (http://www.baxleycompanies.com/Sportchock.html) even if you don't want to bolt it down it makes securing the bike much easier. I use it, some good tie downs (not ratcheting ones) and a canyon dancer and I can load and unload in under 5 minutes.
Kopfjäger
Two "Arched" ramps. One to walk up, one for the bike. I use short tie down straps and fasten the ramps to a point
under the rear bumper. Some type of wheel chock in the bed for the front wheel. (Baxley, or similar)
derby
Quote from: kopfjäger on March 26, 2011, 09:12:38 PM
[thumbsup]
-- derby
'07 Suz GSX-R750
muskrat
here ya go http://www.discountramps.com/motorcycle_ramp_page.htm
oh and once you're going to load the bike keep going and don't stop.  I personally like the three piece ramps because you can take them down to two or just one for a dirt bike.
DON'T DO THIS
Motorcycle loading fail / Black cafe cz
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
The Bacon Junkie
Quote from: muskrat on March 26, 2011, 10:43:56 PM
DON'T DO THIS
that never gets old...  [laugh]
This guys does it wrong too...  [roll]
Motorcycle load FAIL!
While it's not a good idea to have the bike running and feather the clutch to get the bike on the truck if you're not experienced, this guy does okay...
How To Load A Motorcycle Alone
Save the Brass...
I'd avoid the ramps at Lowes etc. They're more geared to atv's and lawn equipment and are more like ladders than ramps, It's easy for a foot to go through.
You want ramps you can actually walk on.
rockaduc
I use my ATV folding ramp which is wide enough for me to walk along side as I load.
Enzoman
I have the same truck 2011, haven't had to load a bike in it yet but they come with the adjustable locking tie downs which are nice and can be moved pretty much anywhere on the rails, and they have a couple hooks in the back mounted to the bed. Theres also storage compartments for your straps and stuff. Only thing I recommend for the truck is that make sure it's the SR5 model with the upgrades, the base model doesn't have intermittent wipers and other convenience stuff that you will regret later not having... they are great trucks though, no complaints so far!  [thumbsup]
Quote from: The Bacon Junkie on March 26, 2011, 11:20:10 PM
This is how I do it. I have a second ramp to walk up alongside the bike though.
Works well.
bikepilot
I usually ride the bike up or worst-case let the bike's motor do the work.  A street bike is too heavy (for me) to push into my pickups (4x4s and sorta tall).  Mostly I use an enclosed trailer with a ramp door though.
2009 XB12XT
2006 Monster 620 (wife's)
1997 TL1000S
1975 Kawasaki H1 Mach III
2000 XR650R (dez racer)
2003 KX100 (wife's)
justinrhenry
#12
i have a little 5'x8' open trailer that i use for hauling my bikes or whatever else.  it only cost me about 700 bucks.  cheaper than buying a whole new truck.  ;)
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
dgm
thanks for all the tips!  A trailer would be cheaper, but I want the little truck for other things as well.  Hauling the bike is just one.  I actually have a perfect spot just outside my garage that would almost put the bed of the truck level with my driveway... would be easy to load I think.  My concern then would be unloading/reloading once I got to the track.  I suppose I just need some practice doing it.  I happen to have a bunch of brand new ratcheting straps from my last truck, but someone mentioned not using the ratchet-type.  Why?
Ddan
Quote from: dgm on March 27, 2011, 08:12:12 AM
Dunno, I use them all the time and they work way better that the cam-lock straps I've tried
Ducati Monster Forum at
www.ducatimonsterforum.org
