April 25, 2024, 09:39:23 PM
Thread seal for gasoline?
Topic: Thread seal for gasoline? (Read 2064 times)
Charlief
April 03, 2011, 10:53:35 AM »
I need to use a thread sealing compound of some sort on a metal to metal fitting. It will be exposed to gasoline.
I looked through the Permatex web site and nothing was mentioned about compatibility with gas. They just listed oil/diesel/hydro.
My local Napa store was of no help.
I'm looking for tape or liquid... What ever works best. This is for a carb so pressure will be minimum.
Turf
Awesome > Logic
Re: Thread seal for gasoline?
April 03, 2011, 11:43:35 AM »
Wouldn't generic red gasket sealent do the job? It's gas proof and I think it'd handle threads
Charlief
April 03, 2011, 11:57:52 AM »
I'm thinking that's what the PO used. There was a red rubber compound on the threads.... And in my fuel lines.... And in my jets. I've installed an in line filter to help solve the "clogging of the jets" issue. I'd like to avoid this problem in the future by using something more specific for the need.
April 03, 2011, 12:18:11 PM »
This is the only thing I have used:
Permatex Aviation Form-A-Gasket Sealant Liquid
http://www.permatex.com/products/automotive/automotive_gasketing/gasket_sealants/auto_Permatex_Aviation_Form-A-Gasket_No_3_Sealant_a.htm
It makes a semi-hard seal that is removable later. 100% gasoline resistant and made specifically for contact with fuels and motor lubricants.
Charlief
April 03, 2011, 12:29:27 PM »
Quote from: ducatiz on April 03, 2011, 12:18:11 PM
Ah.... I was looking under thread sealing. Not thinking
about gasket seal. So looks like both of you guys are right. I wanted to avoid the "rubber" type sealants.
Thanks! I'll look around for some locally. Or order on line.
Last Edit: April 03, 2011, 12:31:24 PM by Charlief
April 03, 2011, 01:09:57 PM »
Advance has it near me
April 03, 2011, 01:10:23 PM »
I hear the yellow teflon tape made for nat gas works for gasoline too.
Supposedly available at Home Depot...
April 03, 2011, 02:35:07 PM »
I have never seen that confirmed. Gasoline is a liquid solvent and NG is neither. I would want to see that in writing.
April 03, 2011, 03:33:08 PM »
Quote from: ducatiz on April 03, 2011, 02:35:07 PM
Nat gas is a liquid at one temp and a gas at another.
I'd call it both rather than neither.
Charlief
April 03, 2011, 03:48:52 PM »
Quote from: ducpainter on April 03, 2011, 03:33:08 PM
That's it in writing right there!!
A friend of mine emailed me earlier and said the same about the yellow tape. I also read it on a Donzi forum.
April 03, 2011, 04:37:19 PM »
Is it also a solvent?
My understanding is that NG is always a gas at the pressures that are present when used for home plumbing, which is what the yellow tape is for -- am I wrong?
But again, I wouldn't use anything that doesn't have a specific statement from the maker or cert body saying it can be used for gasoline or fuel oil. I'm not saying you're wrong, just saying Id err on the side of caution.
April 03, 2011, 04:44:36 PM »
Quote from: ducatiz on April 03, 2011, 04:37:19 PM
You're not wrong.
I'm just reporting what I've heard/read.
I use hylomar on every flange type joint I come across whether it's o-ring or gasket sealed recommended or not. It works for me.
Charlief
April 03, 2011, 04:50:53 PM »
I'm going to try the permatex aviation stuff. There's an Advance Auto a town away
April 03, 2011, 10:00:03 PM »
Use a toothpick to apply a tiny thread of it. That's all you need for fine threads. It will set up in about ten min so screw things in before that. It gets very tacky after that.
Reply #14 on:
April 03, 2011, 10:02:17 PM »
I don't have the link handy but Permatex rtv silicone with the copper is gas proof. The problem folks have is using too much which squeezes into the tank... Use a tiny bead and igts fine.
