February 12, 2025, 07:57:57 AM
Please Help
Seat Scooping?
Topic: Seat Scooping? (Read 3982 times)
Syscrush
Seat Scooping?
April 06, 2011, 09:50:58 AM »
Hey all. We lowered my wife's M620 with the adjustable link from Monster Parts, but she's still on tippy-toe making it hard for her to back up on any kind of incline or slippery surface. Also, we sometimes ride 2-up, and have scraped the exhaust a couple of times this spring (What can I say? I got fat over the winter...
). So we want to adjust the suspension back up a bit and take as much height as possible out of the seat. As such, I have some questions:
1) How much can be taken out without turning the seat into a board? To me it feels like about 3/4" should be doable if some stiffer foam is added.
2) I've seen a Ducati Performance Low Seat that drops about 20mm (in line with my 3/4" guess). It's a bit pricey, but is this a viable/good option for the 620? What are the pros/cons vs. getting a used seat and having it scooped?
3) What is the stock upholstery material? I assume it's vinyl, but it feels nicer than other vinyl seats I've had.
4) If I have the foam cut down/replaced to get 20mm of lowering in the front, will the upholstery have to be cut & stitched to fit?
5) What's a good source for a used seat in Canada? I know that there's eBay, but the stuff I'm seeing on there is in the states, and my usual wrecker apparently doesn't do Ducatis.
Monster Dave
Re: Seat Scooping?
April 06, 2011, 12:38:34 PM »
Buy her some platform boots and save yourself a lot of work.
In all seriousness, here's a way to raise the boot sole height:
http://www.vtwinmama.com/BOOTS_Article_Slate_pdf.pdf
Last Edit: April 06, 2011, 12:42:25 PM by Monster Dave
S2R 800 '07
Re: Seat Scooping?
April 06, 2011, 01:20:39 PM »
20mm is no problem, a little more also ok, especially if you replace with firmer foam.
For easier reach, you will have as much, or more, to gain by reducing the width.
BTW - there's a tutorial about this
Syscrush
Re: Seat Scooping?
April 06, 2011, 01:34:02 PM »
Quote from: stopintime on April 06, 2011, 01:20:39 PM
Good to know.
Quote
Yup.
Quote
NICE! Shoulda checked there first. Sorry.
Syscrush
Re: Seat Scooping?
April 06, 2011, 01:34:58 PM »
Quote from: Monster Dave on April 06, 2011, 12:38:34 PM
Not a fan of thicker soles - makes shifting a pain. Even so, thanks for the link.
Syscrush
Re: Seat Scooping?
April 06, 2011, 01:42:21 PM »
BTW -
here's the tutorial
if anyone wandering in here wants easy access.
Re: Seat Scooping?
April 06, 2011, 07:21:47 PM »
if your following my other thread, i took over an 1inch off.
Syscrush
Re: Seat Scooping?
April 06, 2011, 08:43:14 PM »
Quote from: He Man on April 06, 2011, 07:21:47 PM
This thread
, right?
Did you net a 1" decrease in seat height? I didn't think you were trying to lower the seat from what I read in there...
Syscrush
Re: Seat Scooping?
April 06, 2011, 08:44:11 PM »
Another question: Are the seats from all M620's interchangeable? Will a 2003 work on her 2006 bike?
Thanks again for all of the help and info so far.
Omnipotent Potentate
Personal Pretext
Re: Seat Scooping?
April 07, 2011, 05:03:40 AM »
Quote from: Syscrush on April 06, 2011, 08:44:11 PM
Yes. As far as I know, any monster seat from 2001 on, until the 696 appeared will fit. The exception might be the S4Rs seat... but I think that's same same too.
Syscrush
Re: Seat Scooping?
April 07, 2011, 05:26:44 AM »
Quote from: Sad Panda on April 07, 2011, 05:03:40 AM
Great, thanks.
Re: Seat Scooping?
April 07, 2011, 08:57:14 AM »
Quote from: Syscrush on April 06, 2011, 08:43:14 PM
This thread
, right?
Come to think of it, i took more than an inch off. I put back on 1/2inch gel pad and 1" foam. but the foam compresses to almost nothing, so yea i did gain 1" drop.
Syscrush
Re: Seat Scooping?
April 07, 2011, 11:26:40 AM »
Quote from: He Man on April 07, 2011, 08:57:14 AM
In your thread I thought it says that your goal was to raise the seat?
Re: Seat Scooping?
April 07, 2011, 02:45:31 PM »
its the 2nd time i was working on the seat. the 1st time i took too much off. so im raised it again, sorry if thats confusing,
Syscrush
Re: Seat Scooping?
Reply #14 on:
April 08, 2011, 06:13:38 AM »
BTW - the part # for the factory low seat is 59520204C, but my local dealer says its no longer available.
Correction: that part # has been replaced by 59520202D, and according to shopducati.com it is available. I'm waiting to hear back from my dealer to see if it's available locally.
It's possible that the bike actually has the low seat already - what's involved in determining for sure if the current seat is the low or standard seat? Is there a part# marked/stamped/molded on the seatpan someplace? Is there a measurement I can take?
Thanks,
Phil.
Last Edit: April 08, 2011, 06:55:47 AM by Syscrush
