February 12, 2025, 07:49:44 AM *
Author Topic: ECU reflash + PCIII vs Nemesis on Moded engine  (Read 1066 times)
caperix
« on: April 15, 2011, 02:12:57 PM »
I am getting ready to dive into the top end of the engine on my bike & do a big bore kit, cams & big valve heads.  The bike is an '04 620 so it is prob not the best choise for all these parts but the total investment was less than selling it & buying a 1000.  It will end up being a high compression 750cc engine with 800 heads & cams.  I was thinking of having the ECU reflashed to 800 spec then using a power comander to dial it in from there.  The problem is the price of the reflash & the power commander is approching the price of a nemesis ecu.  Being a 620 I think both choises would require swaping the TPS to a non linear unit.  So far the only draw back to going the Nemesis route I can think of is not every dyno shop would be familure with its software as they are with dynojets.  Any input other than forgeting it & buying a bigger bike?
greenmonster
« Reply #1 on: April 16, 2011, 01:14:36 AM »
http://www.tuneboy.com.au/buy.html + a Dyno & make a custom map?
M900 -97
MTS 1100s  -07
caperix
« Reply #2 on: April 16, 2011, 04:34:52 AM »
That is not an option I was aware of, do you have any experience with it?  They do not list the monster in there supported bikes but the description says it works on all 5am & 5.9 ecus.  I'll have to look into that more, thanks for the link.
brad black
« Reply #3 on: April 16, 2011, 05:38:09 AM »
doesn't work on 5.9m ime, fine on 5am.
Brad The Bike Boy
http://www.bikeboy.org
loves ze desmodromics.
« Reply #4 on: April 16, 2011, 07:55:32 AM »
If there is sentimental value in the existing bike, its understandable. Also, a hopped up bike is more fun to talk about, whether or not performance is mind-boggling, than a pretty plain-jane version.
On the ECU reflash, plus a PCIII - You are going to be modifying the original computer, and adding a piggyback computer to do the job of a single computer: the Nemesis.
If you have a local shop that will spend the (essentially required) "day" to fully map the Nemesis, I think you'd have the best overall setup.
But the unit itself is more costly,and the tune-time is going to add up to bigger $$$ for sure.
Similarly, since I think you'll be needing to work pretty extensively with a shop that has a Dyno, you may also investigate the Microtek systems.
http://www.microtec.cc/cms/en
If you are using a shop, they may have more experience with one or the other: nemesis or microtek.   Certainly something to ask about.
The other I've heard positive chatter about would be the Bazzazz products. I have no FHE though, and not sure they make something that would 'take care' of the whole system, or rather equipment that augments the setups, like Powercommander's PCIII, etc.
