December 28, 2024, 05:21:49 PM
12
13
14
15
135
Topic: What did you just buy for your Ducati? (Read 419672 times)
freeclimbmtb
From Zero Member to
Reply #180 on:
August 27, 2011, 07:04:20 AM »
Quote from: Arachnosold1er on August 26, 2011, 08:34:08 PM
Any chance of a good sound clip of those Arrows?
Got the GoPro...im just trying to figure out a good mounting location and which camera case yields the best sound (without getting too much other engine noise...)
2011 Monster 796 ABS
NateNewThread
Reply #181 on:
August 27, 2011, 01:04:44 PM »
New After Market headlight clamps (thanks DoWorkSon)
Rizoma Timing Belt Cover, Rizoma Rearsets, and Ducati Performance Luggage.
Up Next, Rizoma Sprocket Cover. Maybe exhaust at some point, but I think the stock sounds fine
teddy037.3
Reply #182 on:
August 27, 2011, 01:17:47 PM »
...her replacement.
actually, that's not quite true. got the bike thursday. today I ordered mirrors from Jeff.
jongunz
Reply #183 on:
August 28, 2011, 09:31:47 AM »
Quote from: Duc796canada on August 26, 2011, 08:29:54 PM
Some nice looking bikes! I'm currently happy with the way the bike is and what I'm using it for. Those black levers look good with the black Rimoza Reverse retro mirrors. I'm still trying to find the little plus for the stock mirror holes. I went to some hardware places here in Canada and couldn't find any.
I just flipped mine upside down. No need to plug the holes.
Duc796canada
My first Ducati and road bike!
Reply #184 on:
August 28, 2011, 01:53:46 PM »
Quote from: NateNewThread on August 27, 2011, 01:04:44 PM
Nice. I was looking at the space under the headlight(s), it looks empty, someone should come up with a CF scoop that is also functional in directing ram air to the oil cooler and the engine(for cooling at speed)! Take advantage of the old headlight mounts in the design. :)What do you folks think?
Last Edit: August 28, 2011, 01:56:07 PM by Duc796canada
796 Red Monster(sans ABS)
Viz-Tec Supabrake II
15/41 gearing(AFAM quick change sprocket)
PC V, NEXTUP QS.
2006 Suzuki GSXR 600 track bike(I know...not a Duc...some day)
NateNewThread
Reply #185 on:
August 29, 2011, 05:02:51 PM »
Quote from: Duc796canada on August 28, 2011, 01:53:46 PM
It does look a bit empty underneath but each project has a different result. The reason being that there is no easy aftermarket conversion for the new monsters. Each headlight mod requires custom cluster brackets and the position of the headlight on the forks is up to the rider and what type of fork clamps/brackets they use.
But you do have a point, specifically the old headlight mounts being very visible. I've flirted with the idea of just capping them off or putting some black hardware on them just because they look so damn shiny.
RLSinOP
Reply #186 on:
August 29, 2011, 08:11:23 PM »
Quote from: RLSinOP on August 26, 2011, 07:23:08 PM
Finished Phase 1 of my mods. They include: Arrow slipons, motovation front axle and frame sliders, CNC alternator cover, evotech tail chop, leverskinz, rizoma barends, and even some ducati valvestem caps I found on ebay. Ordered a billet front sprocket cover but the color (red) was horrible. Almost pink. Also ordered Rizoma Sportline grips. Put them on and didn't like the look, feel, and they left 8mm of the handle bar showing, so took them off. Also got rid of all those horrible frame stickers which now live under the seat.
Next up are rear sets (can't wait to lose those horrible passenger pegs and bars) and mirrors.
Well, I'm having a hard getting the modification addiction under control. Today I purchased a CNC Racing rearset, Rizoma mirrors (radial), a Rizoma front sprocket cover, ducabike covers for clutch, front brake and rear brake reservoirs, a new rear sprocket hub and an Oberon clutch slave. This stuff all came from Randall at Bellissimoto - who is beyond excellent and helpful. The only problem is that he mentioned I should not stop here and go ahead and get belt covers and a steering damper.
The addiction continues.
RLS
S4ROB
Reply #187 on:
August 29, 2011, 10:40:35 PM »
"Well, I'm having a hard getting the modification addiction under control."
LMAO Ain't gonna happen
I just installed this slipper clutch a couple weeks ago, WOW what a difference.
"Guns. You think you have enough, until the ZOMBIES come."
Gunslinger's Journal
timeforpoptarts
Reply #188 on:
August 30, 2011, 02:44:03 AM »
Cortech tail bag enroute for my ride to Virgina this weekend, and hopefully Ocean City as long as Irene didn't completely destroy it.
'11 M796 ABS
teddy037.3
Reply #189 on:
August 30, 2011, 08:02:48 AM »
hugger/chain guard, and frame sliders.
it's going to be a busy weekend, install-wise
timeforpoptarts
Reply #190 on:
August 30, 2011, 08:12:25 AM »
Love the headlights.
'11 M796 ABS
Reply #191 on:
August 30, 2011, 12:58:37 PM »
Quote from: timeforpoptarts on August 30, 2011, 02:44:03 AM
Pretty sure Ocean City was mostly spared.
NateNewThread
Reply #192 on:
August 30, 2011, 01:05:19 PM »
Quote from: timeforpoptarts on August 30, 2011, 08:12:25 AM
drunkfatguy
Reply #193 on:
August 31, 2011, 07:16:20 PM »
Just bought a 14 tooth Drive gear.
77south
Reply #194 on:
September 01, 2011, 06:55:10 AM »
Just got a lightly used termi racing exhaust kit for my sport 1000s. I will post pictures when it is installed next week.
12
13
14
15
135
