Started by DucatiTorrey, April 17, 2011, 11:28:22 AM
Ddan
That bike crashes very well, you don't need to worry about it    ;D
Quote from: ducpainter on October 19, 2018, 04:50:55 PM
Yup...a 91 900...I think it's a 91. It was Ddan's bike.
I think I'm going to move the flat slides, and the top end with the high comps, to my Monster motor. I'll swap motors because the SS motor has the really uncommon short crankshaft. Left side covers are relative unobtanium. For a track bike crashing is a given so I don't want to trash that motor.
Ducati Monster Forum at
www.ducatimonsterforum.org
Qomomoko
Quote from: dufukincati on October 13, 2013, 03:12:35 PM
Bursig paddock stand  8)
Looks great!
I have a Bursig stand too but sold my R1 2015 1 year ago. Have been trying to get the right adapter plate from Bursig (Patrick) but
look like it can not be obtained any longer. I am in contact with them again, a year later and 2 wrong adapter plates ordered, and hoping for better results.
Can you provide any help, insight into your set up, order, magic???
Thanks
Maybe you should ask a local machine shop to fab one up.  That post is 7 years old man...
Pinion
Quote from: Qomomoko on April 26, 2020, 03:52:48 AM
Looks great!
Thanks
Revzilla, eBay and bersig they still make plates
There are also other lifts companies that have copied bersig
Will trade toilet paper for parts
Pinion
Today, gas. 1st time in over a year, I'm excited
The ModFather
Fuel Injectors for repair on the S2R800 and an Oberon Clutch Slave the Sport Classic
2007 Sport Classic 1000S
2008 848 Track Bike
2015 Diavel Dark - Sold
2005 Monster 620 Dark - Sold
Red Ducabike engine breather for my wife's M1000S.
Engine O-rings to repair an oil leak on her M1000S.
O-rings to swap the M750 head studs holding on the horizontal head of the Coup D'etat (900 engine).  Also to swap the vertical head with a brand new 0-mile OE head I found on eBay.  (W stamp, so no one wanted it.)
My Keihin importer got a lead on a Motion Pro type quick turn throttle for FCRs that uses the existing cables. Ordered them to reduce wrist angle.
wataboy
The old MotoBatt finally died so I figured I'd give Shorai a try. Read many post about the weight difference but it's really unbelievable when you hold them side by side. Install was dead easy...got it tucked in nice & tight. Can't wait to take it out to see if I can tell a difference in handling.
Guessing that's an LFX18 ?  Shorai batteries feel so light it eels like the fuel tank is empty. Where did you put the Ignitech?
New tyres for the M750. Since its scramblerfied they are MT60RS like the Ducati Scrambler but in M750 sizes.
herm
New Pilot Roads front and rear
New belts
Valve job/check
I'm sure Eric will add more to the list 8)
wataboy
Quote from: koko64 on July 16, 2020, 10:53:16 AM
The IG's been riding between the right FCR & the frame for a couple years. I may move it to the battery box now that there's room.
   Some thin adhesive foam and it slots right in there. [thumbsup]
