December 28, 2024, 04:26:28 PM *
Pages: 1 ... 19 20 [21] 22 23 ... 135   Go Down
Author Topic: What did you just buy for your Ducati?  (Read 419243 times)
« Reply #300 on: December 31, 2011, 12:17:27 PM »
Led turn signals, mirrors, black exhausts.
DTR
« Reply #301 on: December 31, 2011, 08:28:54 PM »
Clubman bars and Brake/clutch MCs and levers off a 6XX series Monster.
Desert Dust
Ten Most Popular Uses for a
« Reply #302 on: December 31, 2011, 09:44:01 PM »
848 carbon fiber front fender and Ducati/Corse emblems
07 S2R 1K:  "You are not special. You're not a beautiful and unique snowflake. You're the same decaying organic matter as everything else. We're all part of the same compost heap. We're all singing, all dancing crap of the world.”
bobbybirds
« Reply #303 on: January 04, 2012, 08:31:31 PM »
Just received a Quat D Ex-Box system for my 2008 S2R1000... Can't wait for spring!
Goat_Herder
« Reply #304 on: January 05, 2012, 12:59:14 AM »
my chain lube is running low.  Just got some resupply.
Goat Herder (Tony)
« Reply #305 on: January 05, 2012, 03:16:43 AM »
^  Need to go grab some of that.
sebastienb
« Reply #306 on: January 09, 2012, 05:31:54 PM »
Got an evotech fender eliminator and a case to mount iphone to handlebars
Twizted
« Reply #307 on: January 10, 2012, 03:06:37 AM »
Do you find the screen on the iPhone flips around from side view to normal view when going around bends?
freeclimbmtb
From Zero Member to
« Reply #308 on: January 10, 2012, 06:11:16 AM »
I didnt JUST buy it, but I forgot to post when I did.  Came up when I was half way home on a Sunday afternoon on my return trip from San Francisco to San Diego.  God bless the guys at cyclegear in SLO.
So...
also...
 Grin
2011 Monster 796 ABS
monsterdan
« Reply #309 on: January 10, 2012, 06:35:39 AM »
Yes and not even on bends sometimes just lane changing does it - really annoying when in TomTom GPS app!! should be able to desensitise the function 😠 grrr
Getting back to the subject.... Santa bought me:
- Motovation sliders - frame / forks / swing arm / bars
- Gilles black rearsets
- Rizoma black handlebars
- Renthal Grips
2010 Monster 1100 - Fitted:Gilles Rear sets - Rizoma bars - AVS Levers - Motovation sliders - DP Carbon - DP Touring Seat.  On the way: Cyclecat Pressure Plate, CNC Clutch Cover.  So much more to do.....  ;-)
freeclimbmtb
From Zero Member to
« Reply #310 on: January 10, 2012, 07:11:37 AM »
- Renthal Grips
makethebeastwithtwobacks me sideways with a lunchbox...I wish santa was that good to me!!!
« Reply #311 on: January 10, 2012, 08:27:57 AM »
my andoid has a way to lock the screen in one mode.
tristantumble
« Reply #312 on: January 10, 2012, 08:34:45 AM »
hey i just got the same turn signals, but dont have that third box with the wires. is that needed for the install, or can you use existing wiring?
« Last Edit: January 10, 2012, 08:58:25 AM by tristantumble » Logged
07.695 (sold)
07. sport 1000 biposto
freeclimbmtb
From Zero Member to
« Reply #313 on: January 10, 2012, 09:03:33 AM »
Those adaptors allow you to retain the stock plug on the harness and avoid cutting your stock turnsignals, basically they make the blinker install 100% reversable.  But yes, if you arent afraid of some cutting and splicing (either crimp connectors, or solder and heatshrink) then you can definitely install the signals with out the extra wires.
On another note, they manual stated that I not need any of the resistors for my bike, when you install them, plug everything in, put the bike to on and hit the switch.  If the blinker is too fast, add a resistor until it looks right. (if you go by the pictures, 1 resistor is for an 8W to 12W bulb...which the 796 has...for some reason the manual said to use none.  oh well, works great now!)
sebastienb
« Reply #314 on: January 10, 2012, 01:50:34 PM »
Yea it does but you can lock the screen, I mostly keep my phone in there in case i get a text msg of important notice while heading somewhere. And to find miami backroads to avoid traffic
Pages: 1 ... 19 20 [21] 22 23 ... 135   Go Up
