February 12, 2025, 07:44:06 AM
No clutch cover
Topic: No clutch cover (Read 1682 times)
theduc
No clutch cover
April 17, 2011, 05:49:06 PM »
I see that some people are running with no clutch cover and am thinking of doing the same. If you remove the clutch cover do you need to get shorter bolts to put back in the case or are the original ones ok to use. I just don't want to crack the case with bolts that are to long.
Thanks .
The best kind of whore is a
Re: No clutch cover
April 19, 2011, 06:06:05 AM »
You can use the originals.
I've done it.
chris1044
Re: No clutch cover
April 19, 2011, 08:08:42 AM »
Since you only have 4 posts, maybe you should investigate what happens when you run no clutch cover and dump the bike over on your right leg before you go this route
zarn02
Re: No clutch cover
April 19, 2011, 09:47:14 AM »
Quote from: Monsterlover on April 19, 2011, 06:06:05 AM
I've done it.
+1
OT
Still Sweeping.....
Re: No clutch cover
April 19, 2011, 07:27:41 PM »
+2, but only on very hot days...
There are a few in here.....
http://www.ducatimonsterforum.org/index.php?topic=2789.0
Last Edit: April 19, 2011, 07:29:57 PM by OT
theduc
Re: No clutch cover
April 20, 2011, 06:16:59 PM »
Thanks for all the info
Punx Clever
Re: No clutch cover
April 21, 2011, 04:16:12 AM »
I've done it... but it's cheaper to replace a clutch cover than a clutch drum / springs / retainers and possibly pressure plate when you accidentally drop the bike either stopped or moving.
2008 S2R 1000 - Archangel
The Edge... there is no honest way to explain it because the only people who really know where it is are the ones who have gone over. - HST
uglyducky
something, words, clever . . .
one way to do this is we can all get naked . . .
Re: No clutch cover
April 22, 2011, 04:23:29 PM »
ya, use something or pay a lot when you make a mistake.
2001 996 Biposto - (sold)
