Throttle Cable Issue 1100 Monster
Started by Lowhog, April 19, 2011, 08:34:06 PM
Lowhog
I installed Rizoma Risers (60mm) on stock handle bar.  It raised the bar about one inch.  Problem is when you turn the bar to the hard left it pulls the cable and throttles up the motor.  I rerouted the cable to the back side of the tripple tree so I can ride it but don't like how the cable is positioned.
So my question does anybody know if their is a factory cable that is 1 to 2 inches longer.  All other suggestions would be appreciated.  Thanks for your input.
Moschy
Hi,
get the throttle cabel of the current Hypermotard. Clean swap for 25 $.
Be mindful of your thoughts. They'll betray you.
Lowhog
Will order one tomorrow.  Interesting the parts person was lost when I asked the question and the wealth of knowledge here delivered.
Appreciate your help.  I have to assume you did something like this.
Best Regards
Moschy
Yap. I've got most of the 1100 stuff on my 696 (handlebar, clutch and brake cylinder...) plus the lower part of the 796 clamp which is 20 mm higher than stock.
