November 23, 2024, 06:11:09 AM *
News: Please Help
Pages: 1 ... 151 152 [153] 154 155 ... 208   Go Down
Author Topic: The "Official" Oz Monster Say Anything Thread...  (Read 391910 times)
monstermick58
« Reply #2280 on: February 11, 2012, 02:04:16 AM »
get a flat screw diver ,grind to just slightly bigger the allen head then grind each side like a knife gently tap in and place a set of clamp plyers om the screw driver handle and undo easy  waytogo cheers bazz
+1 on what Bazz said
use a square shaft screwdriver
or a 5.5 mm hex key filed down a wee bit and gently tapped in using a soft face hammer
                               Mmick
monstermick58
« Reply #2281 on: February 11, 2012, 02:26:30 AM »
Was having brake shudder on the ST so had a secondhand set of brake rotors in the shed, thought I'd fit them up today, did notice that the centre's were slightly different.
Original rotor on the left, replacement on right
Bit of difference in Diameter
On they go.
Hope they work OK.
                                    Mmick
FIFO
Doing the latter
« Reply #2282 on: February 11, 2012, 03:06:42 AM »
Hey Mick looks like the originals are 2.5 inches  which seem odd for an italian bike Shocked and the after market are 64 mm bore.
I personly wouldn't do it.
May be on Teffs bike though Cheesy
monstermick58
« Reply #2283 on: February 12, 2012, 01:30:05 AM »
No Rob,
       Both set of disc's are genuine Ducati, the set I've just put on I bought secondhand 3 years ago but I've not had time to check to see if they are ok.
                                    Mmick
Betty
« Reply #2284 on: February 12, 2012, 01:59:59 AM »
Isn't that what Joe is for?
Wells
« Reply #2285 on: February 12, 2012, 06:16:24 PM »
Really? I'm kind of surprised. For a difference of 0.3mm you wouldn't run them?
If your bolts line up, the offset is the same, the disc/pad contact area is the same then who cares what the hub size is so long as it fits?
Mick - I'm sure you've already done this, but I understand it might be worthwhile changing pads when swapping discs so that the new pads bed in to the new discs (or some such thing).
2005 M620
Hi. I’m Troy McClure. You may remember me from such self-help tapes as “Smoke Yourself Thin” and “Get Some Confidence, Stupid!”
NYTimes: "...highlights of his global tour include encounters with Nelson Mandela, an 800-year-old demigod and a dildo collector."
suzyj
Does my bum look big on this?
« Reply #2286 on: February 12, 2012, 06:58:57 PM »
Agree with Wells.  0.3mm is the thickness of a coat of paint.
That said, they look as ugly as sin.
Wells
« Reply #2287 on: February 12, 2012, 09:01:41 PM »
Yeah, not a huge fan of the steel carrier ones either.
That being said.. I'd take the aesthetic hit if it meant no shudder under brakes... especially at speed.
2005 M620
PAUL M
S4RS
« Reply #2288 on: February 12, 2012, 09:09:38 PM »
Hey, they look good Embarrassed same as mine
Two dogs
« Reply #2289 on: February 12, 2012, 09:59:03 PM »
They also have a nice slimming effect on your derriere Paul  laughingdp
PAUL M
S4RS
« Reply #2290 on: February 12, 2012, 10:12:13 PM »
 that's right....chicks love it
Two dogs
« Reply #2291 on: February 12, 2012, 10:20:12 PM »
Thanks for sharing your school photo with us. applause
Wells
« Reply #2292 on: February 12, 2012, 10:47:14 PM »
I can't dig up.
Sorry Paul.
2005 M620
FIFO
Doing the latter
« Reply #2293 on: February 12, 2012, 10:55:24 PM »
I guess .3 might as well be 30mm.
Then you are only only relying on the bolt holes to make the disc run true /concentric.and if there is a fair bit of clearance in the bolt holes the the disc will  have the potential  to oscillate.
And the run out will be far greater on the out side diameter,giving a pulsing affect.
You are also relying on the bolts to stop any radial movement. rather than the locating hub on the wheel.
The possible worst case scenario
 the disc could have the potential to flog it self out on the bolts.
or the bolts to shear under load,thus no brakes, but hey you still have a back brake. Wink
But  hey you two are the Engineers you can sign of on it Cheesy
And +1 on the ugly bit vomit
And to quote Betty, Believe post content at your own risk. Lips Sealed Undecided Huh?
« Last Edit: February 12, 2012, 11:58:54 PM by Rob s » Logged
Wells
« Reply #2294 on: February 12, 2012, 11:56:26 PM »
ahhh okay, now I see what you're saying, concerned about Radial oscillation/movement..
I've seen plenty of bikes with clearance around the hub and being secured, aligned, etc by "just the bolts".. Doesn't mean it's right though.
In my VERY limited experience I've not seen it as an issue so long as there's not much play in the bolts/holes... I'm surprised to hear that the expert opinion of people like yourself is different to what I would have thought.
Wouldn't the best answer for
be "... then find some new discs"?
Oooh, that's a bit below the belt...
Firstly, I think we're both electrical engineers.
Secondly, my degree should be all but revoked having not worked in the field for years... now all it proves is I knew how to do maths once and I was too stupid to change to B.Sci or something like that.
2005 M620
Pages: 1 ... 151 152 [153] 154 155 ... 208   Go Up
