February 14, 2025, 10:04:53 AM
cross country from LA to NY: southern or northern route?
Topic: cross country from LA to NY: southern or northern route? (Read 3225 times)
hydra
life is analog...
April 22, 2011, 10:48:07 AM »
hello folks,
i'm taking a cross country trip to move a bunch of audio equipment and instruments. i'll be driving a minivan loaded to the max. main routes would be I80 for the northerly route or I40 for the southernly route.
mainly trying to avoid LEO and bad road conditions. i've driven both routes but from NY to SF awhile ago so i can't remember which one i favored. any input from you guys would be great.
ciao
admins: please move this if it's in the wrong section
S4 Foggy- tires, battery...
BE WATER
happily everafter
Re: cross country from LA to NY: southern or northern route?
April 22, 2011, 11:14:53 AM »
northern route is a little more scenic, but you'll be travelling into the higher elevations & more twists & turns... southern route is flat, less scenic & i believe the speed limits are higher the southern route. also the northern areas are still getting snow. if you aren't wanting to sightsee & you're just wanting to get there.. i'd go the southern route
If you love 2 people at the same time, choose the 2nd one. Because if you really loved the 1st one, you wouldn't have fallen for the 2nd....
One's past is what one is. It is the only way by which people should be judged.
~Oscar Wilde
One cannot and must not try to erase the past merely because it does not fit the present.
~Golda Meir
drunkfatguy
April 22, 2011, 05:41:12 PM »
I'd say stick to the southern route until you get past the Rockies, the higher altitudes will reduce the power of your minivan that is loaded down making some of those roads a little Interesting to go up.
hydra
life is analog...
April 22, 2011, 06:23:54 PM »
thanks for the input drunkfatguy and monster quack!
good points about the snow and hilly terrain. i'll be loaded up with over 1000 lbs of gear.
southern route it is.
cheers
BE WATER
happily everafter
April 22, 2011, 09:58:20 PM »
you're welcome
~Oscar Wilde
~Golda Meir
justinrhenry
Super
weeeeee!!!
April 24, 2011, 05:32:59 AM »
i'd choose whatever's fastest so i could spend the least amount of time driving a minivan.
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
muskrat
April 24, 2011, 01:46:16 PM »
On the right "Southerly" route you'll find tons of fun. Hit the Smokies then into Western TN via a southerly route form Nashville onto the Natchez trace. Then bounce up and over to Arkansas and hit the Eureka Springs area. Head south towards Texarkana, TX, and then via Palestine and onto Austin and then Bandera (three sisters 335,336,337). Head South to Big Bend starting at Alpine and then out through Marfa and into El Paso. Go towards Almogordo, NM and then off towards Fragstaff or north of Santa Fe, NM, go into the San Juan forest into Purgatory/Durango, CO. It will be scenic and fun!
Can we thin the gene pool?
2015 MTS 1200
09 Electra Glide
The Bacon Junkie
I have a Bacon Wrapped
Save the brass...
April 24, 2011, 04:47:15 PM »
I've driven NY to LA at least 4 times now... I think.
Never in reverse, but I always took the southern route. Time was always of the essence, not sightseeing. I made it in 2 1/2 days on about 6 hours of sleep my first time.
I don't recommend that... I've slept in the Denny's parking lot in Flagstaff, AZ all 4 times.
Save the Brass...
hydra
life is analog...
April 24, 2011, 10:56:34 PM »
Quote from: justinrhenry on April 24, 2011, 05:32:59 AM
too true!
BE WATER
hydra
life is analog...
April 24, 2011, 11:05:55 PM »
Quote from: muskrat on April 24, 2011, 01:46:16 PM
sounds cool but i just need to get there as fast i can. my schedule is tight to get this gear to a project i'm starting in NYC. but thanks for sharing.
Quote from: The Bacon Junkie on April 24, 2011, 04:47:15 PM
wow 2.5 days and 6 hrs sleep, must have had some illegal substances with you
i made it in just over 3 days from NY to SF with a co pilot and that wasn't exactly easy either.
thanks for the input.
BE WATER
The Bacon Junkie
Save the brass...
April 25, 2011, 05:44:34 AM »
Quote from: hydra on April 24, 2011, 11:05:55 PM
No illegal substances... just lots of coffee and a small cooler filled with my mom's meatballs!
Save the Brass...
hydra
life is analog...
April 29, 2011, 06:21:56 AM »
i just got back yesterday after only 2.5 days! we did 1400 miles the first day with 12 hrs each round.
thanks for the replies and input!
BE WATER
