carbon fiber mufflers
Started by polivo, April 24, 2011, 07:16:52 PM
polivo
What are you guys using to clean and protect your carbon fiber mufflers?  My ak's are less than  a year old and the end caps seem to be yellowing already?!?!?
rockaduc
Soapy water with a rag stuffed in the end to keep water from getting in the can
CETME
i've used just spray detail wax.
2001 Monster S4
2004 Aprilia Tuono
1992 Honda Nighthawk 750
DucatiTorrey
ive yet to get a clear answer to the yellow problem
  - real place
Kopfjäger
Quote from: DucatiTorrey on April 25, 2011, 11:20:25 AM
They turn yellow because they are not clear coated. I have heard before that WD-40 will remove it. (?)
zarn02
"At the request of another forum member, I looked into the reasons for carbon fiber pipes yellowing. I don't own them but I understand that there is some question as to why the carbon fiber pipes (and any other carbon fiber parts for that matter) yellow over time. The yellowing is presumably due to some degradation over time. Here is what I found:
Carbon fiber parts are made by coating carbon fiber fabric with plastic. This composite is more accurately known as carbon fiber reinforced plastic, CFRP. The carbon fiber fabric doesn't degrade; graphite is the lowest energy state for carbon (look out ladies, your diamonds will be nothing but graphite in mere millennia) and is very stable to heat, light, moisture, oxygen, etc. The plastic that is used to make the part yellows over time due to breaking of chemical bonds of the polymer. I knew that Travis, what causes these bonds to be broken?
Many plastics are used for CFRPs depending on the application but it appears as though the most popular plastic used for auto/cycle parts is epoxy resin. Please let me know if anyone happens to know what plastics are present in commercially available aftermarket pipes. Epoxy resins can be degraded by exposure to various factors: oxygen, moisture, heat, and UV light are the most common. Just sitting on a shelf they will degrade over time due to exposure to oxygen. This chemical reaction between the plastic and oxygen is called â€" surprise â€" oxidation, and is usually pretty slow with plastics, so nothing to worry about there…yet. Degradation due to moisture is mostly limited to marine applications where the epoxy is in constant contact with liquid water, so isn't worth mentioning in this discussion.
Heat typically doesn't degrade the plastic by itself (near room temperature), but it accelerates the oxidation process. In general, the rate of oxidation doubles for each 10°C (18°F) rise in temperature. This is a common way to accelerate the aging process for medical plastics to determine shelflife. So epoxy, as with any plastic, will degrade faster with an increase in heat. If room temperature is 20°C (68°F), when your pipes get to 60°C (140°F) they are being oxidized at approximately 16 times the rate as they do sitting on a shelf somewhere. Does anyone have CFRP pipes and access to an IR thermometer? I would be interested in the temperature of the shell after riding and after just sitting in the sun. We could come up with a ballpark number for how fast they age on a bike versus sitting on a shelf in a store.
UV light is probably the biggest cause of yellowing of CFRP parts. UV light breaks chemical bonds and creates radicals. Radicals are nasty creatures (except in my academic research where I use radicals for the good of mankind) that wreak havoc on plastics. The reason that radicals are nasty with respect to polymer degradation is that when a radical attacks a chemical bond, the reaction often produces another radical that can then go on to attack another chemical bond. It's not a true chain reaction but the result is several chemical reactions from a single photon of UV light, making this a much more destructive pathway for a given energy input.
Nothing is that simple, there is a synergistic effect when all of the degradation factors are involved, but UV light and heat in that order likely cause the most damage. I would recommend protecting your CFRP parts from sunlight as much as possible. You can't protect them from the heat but you can protect them from the light anyway."
Stolen from here.
battlecry
Make sure the insulation has not blown out and you are seeing heat damage.
polivo
Thansk for all the tips. I guess I should be more specific.  The mufflers are less than a year old.. and only the end caps are starting to shjow some yellowing. The bike has never left outdoors over night. always garaged. Is this  a manufacturing problem? Did akrapovic forget to clear coat the end caps? should I contact them.. or should I just put some "protect all" on them? see how it goes?
DucatiTorrey
Quote from: polivo on April 25, 2011, 02:08:47 PM
alll the metal end caps...
get some polish, stainless steel polish ectually, or cleaner, i used my eco friendly SS grill cleaner. Being eco friendly made me think it might be easier on the metal?? anyways, it will come out. I bet its more on the left side too huh? figured. Youll learn grasshopper.
  - real place
desmodoktor
i use windex for my arrows.. i guess i have the clear coat on them coz i don't see any yellow coming up  :o
IG @desmodoktor & @ridingturtlegarage
Kopfjäger
Quote from: DucatiTorrey on April 25, 2011, 05:14:51 PM
I believe his cans have a CF end cap. (?)
Roaduser
#11
i havent seen such pipes!?!?
EDIT: i lie.. google showd me what i have previously seen.. they would be a kind of cf cover over the metal end caps.
so is the OP talking about metal end caps or CF ones?
i have an interest in this as my DP remus CF high mounts have no colouring at all and they are 8yrs old!! i even removed the strap hangers to see what was under them and the only difference is a minor amount of gloss.  ;D
polivo
guys, i have the cabon fiber muffler.. with carbon fiber end caps.. looks like this: http://www.surfsidemoto.com/store/product/AKRDU11.html
