Must read Ignitech TCIP 4, Ca-Cycleworks exact-fit coils, Spark plug info
Started by avizpls, April 26, 2011, 05:46:40 AM
avizpls
Quote from: ducatiz on May 09, 2011, 08:10:08 AM
\  I wonder if they did it just to prevent people from cracking it open and duplicating the EEPROM
Probably a mix of that and this is the easiest way to package them. A company like this will usually rightfully take some steps to protect IP
#11
greenmonster
QuoteIt could be the solution to many instances of failed ignitechs.....Cautiously optimistic
So you`ll be able to find a real cause to these units failing?
M900 -97
MTS 1100s  -07
avizpls
#77
I honestly hope so. What spark plug were you running when yours died?
I got my last and final ignitech yesterday (thanks Chris!) and I havent even hoooked it up yet. I will probably do that today. I will start it in the garage, then I will go out on it tomorrow....maybe later tonight. Either way, I'm not calling it just yet. It will need to make it thru a day at NJMP before I trust it again. (so I'll report back on monday morning with my conclusion). Keep your fingers crossed!
#11
are you implying that spark plug choice is killing these units?
avizpls
#11
avizpls
Fortunately, I have had enough of a data set now that I will know pretty much for sure soon.
#11
Langanobob
I had a guy take a look at mine -- they are epoxy filled so all the guts are sitting inside, buried in epoxy.  It's a curious choice given other electronic devices (such as the PCIII) are not and work fine.  I wonder if they did it just to prevent people from cracking it open and duplicating the EEPROM
I think potting electronics in epoxy is a fairly common practice for electronic device that are subject to vibration.  Pretty sure the MSD ignitions are potted, or at least used to be.  I don't think potting would stop a serious EEPROM reverse engineering type, but not being one myself, I really don't know.
Bob
Quote from: Langanobob on May 10, 2011, 03:30:37 PM
Bob
Well you're right at least as far as the stock sparker boxes -- they are potted.  But the PCIII is not, just rubber mounted inside a metal case.
Quote from: avizpls on May 10, 2011, 10:06:50 AM
Thats whats being implied to me
Please tell us soon. I'm sweating on my Igniteck. I'm running NGK Iridium plugs Resistor type DPR8EIX-9 or standard resistor type NGK DPR8EA-9. Could the issue be resistor Vs non resistor type plugs?
greenmonster
QuoteWhat spark plug were you running when yours died?
Mine is not dead, happy w it.
Really surprised, this is the first time I`ve heard of them dying.
M900 -97
MTS 1100s  -07
Quote from: greenmonster on May 11, 2011, 03:42:07 AM
How many have you used?  I assume ca-cycleworks has dealt with more than a sample size of 1.
I have had 1 and it is still working.  Therefore, I have only seen a 100% success rate.
greenmonster
#86
I`ve used 3, my friend w mates 9, I know 3 more that uses it.
If it was a bad quality product in general, I think we all would have noticed that earlier in various Forums etc.
M900 -97
MTS 1100s  -07
Quote from: greenmonster on May 11, 2011, 04:50:45 AM
I used 3, my friend w mates 9, I know 3 more that uses it.
what generation?  i.e. model?  70 75 80?
greenmonster
On my M900  1997 in summer 2007, that`s when I started the megathread at TOB.
3rd on my father`s Suz 400 last summer.
Monster, dunno version, probably 70 or 75, it did not have a default Duc setting nor Ducati Kokusan map.
Where do I find version number?
M900 -97
MTS 1100s  -07
avizpls
#89
Quote from: koko64 on May 11, 2011, 02:35:33 AM
I was using DR8EA NGK plugs last year with the TCIP4 and Stock coils with no problem.
I wanted to upgrade to CA-Cycles red coils. Per there sites recommendation, I got D8EA plugs to go with them. (I just looked at the site and I dont see this recommendation. Maybe I was imagining it...either way, I did switch to the D8EA plugs)
Ignitions started dying. 3 to be exact. I changed variables on all three, but never thought of the plugs. I changed coils, wires etc.....
I put NGK plugs DR8EA in last night and it runs fine. I havent rode it yet, and  I wont until the track day this weekend so the real verdict comes after that.
But Ignitech says you must use a 'R' plug (which you are) and I inadvertently strayed away from 'R' plugs and my problems started. Everything adds up that yes, Non resistive plugs are the problem. I will feel more confident saying this on Monday....or I'lll have a different story all together.
#11
