April 28, 2024, 08:41:54 PM
695- what is too hot?
Topic: 695- what is too hot? (Read 2695 times)
tristantumble
June 14, 2008, 12:24:07 PM »
i know this has been talked about a lot, but after my ride today my bike got up to 298 F. The bike has 800km on it total, is this because its still breaking in, or is that getting to the running dangerously hot zone? I'm going in for my first 1000K service check soon, should i tell the dealer?
thanks.
TT
07.695 (sold)
07. sport 1000 biposto
El Matador
Do I need knee pucks for my
Re: 695- what is too hot?
June 14, 2008, 01:32:22 PM »
Quote from: tristantumble on June 14, 2008, 12:24:07 PM
thanks.
TT
temps go down a bit after the break in period is over.
but they're still pretty high...
After I installed the termi system, I saw my temps drop drastically. It sucks that you have to shell out 1500 to get the bike to run right, but imho it's worth it. Also, I read somewhere that people have had some luck with the dealers getting them a dp ecu?
tristantumble
June 14, 2008, 02:10:43 PM »
Quote from: chipo on June 14, 2008, 01:32:22 PM
is that the full system or slip ons? i'll try to see if my dealer will do anything in terms of dp ecu.
thanks
07.695 (sold)
El Matador
June 14, 2008, 02:24:55 PM »
Slip ons with ecu and open airbox. That's the only one they offer for the 695...
Good luck!
June 14, 2008, 04:06:20 PM »
338
0
F is too hot.
desmopr
June 14, 2008, 04:13:19 PM »
was the bike idling like in a light in Florida weather?
2001 Monster 750 (SOLD)
tristantumble
June 15, 2008, 04:16:51 AM »
Quote from: desmopr on June 14, 2008, 04:13:19 PM
yes, but i was doing city driving, so stop and go, and even as i started to go, the temp seemed to be going up and up.
07.695 (sold)
Wonked
June 15, 2008, 07:11:11 AM »
+1 on the full termis. I have an 07 695 as well that ran pretty hot (approaching 300F). After I opened the airbox , put the chip in, and added the slip ons my bike rarely gets over 245F.
It's an expensive mod, but there seem to be more and more reasons to do it. It looks better, sounds better, is lighter, and makes the engine run a bit cooler.
Armor
June 16, 2008, 08:41:31 AM »
You're talking oil temp and not water temp. Most air cooled bikes do not have a temperature gage.
sbrguy
June 16, 2008, 09:04:18 AM »
add the oil cooler on, the temps will rarely get over 250 again.
Wonked
June 16, 2008, 09:30:55 AM »
Keep in mind there is certainly harm to be inflicted by running too cool. IMHO, you should either add the oil cooler
, or the termi kit
June 16, 2008, 10:57:27 AM »
Quote from: Wonked on June 16, 2008, 09:30:55 AM
, or the termi kit
When oil does not reach sufficient temperature moisture and other contaminates are not boiled out. Check your oil site glass on a cold day. That mayonnaise like substance covering the sight glass is from oil being too cold.
