oil filter wrench
Started by dan miller, May 03, 2011, 11:40:28 AM
ductech31
I don't have a part number, but Cycle Gear has ones that work great.
Just a word of caution, K&N filters restrict flow too much, it's best to use Ducati's own or a HiFlo,  these both work good on Duc's
Quote from: bergdoerfer on May 03, 2011, 07:36:34 PM
next time man up and put some effort into it [cheeky]
My bad.
Guess all those years being single and playing bass have left me with forearms like that of a little girl.
Maybe your really a lefty.
10-12 Nm (Ducati's fatory recommendation) without some sort of tool requires the grip of a gorilla.
Here is a link for a tool for the factory filter:
http://www.motostrano.com/ducoilfilwre.html
The K&N can be removed and tightened with a socket, 17 mm IIRC.  No torque wrench?  7/8 turn after O ring makes contact will work.
64duc
#19
Quote from: howie on May 03, 2011, 09:13:15 PM
You can buy that for $5.99 at your local auto parts house.
This is the type I use.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_OIL-FILTER-WRENCH-Mountain_26941895-P_N3401A_T|GRP2082_____
94 M900, 64 Diana 250
corey
my torque wrench isn't accurate at those low specs. i just put the thing on and tighten it.
DarkStaR
I like using the cap type when possible, but I have OEM filters of different shapes and sizes, so I havent bothered to buy one yet for the duc.   >:(
dan miller
There isn't much of the filter sticking out of the case.  I wonder if it might be the filter.
I ordered some from a buddy - didn't specify the brand - and he sent me several "Fram" filters.  Truth be known, if I had known that he was going to send "Fram" filters, I would have asked for some other brand.  Plus, they're chrome, which I dislike.
Thanks for the help. Danny
P.S.  He's my racing partner, and has a Motul sponsorship.  I use it in my hemi, and like it.  He got a case of Motul motorcycle specific oil that I just installed.  Goofiest light green color that you ever saw.  Politically correct oil - whoda thunk?
Quote from: ductech31 on May 03, 2011, 07:42:12 PM
~~~SNIP~~~
Got any data/link/article to back that up?
booger
#24
HiFlos are K&N copies so you are contradicting yourself. I take it you haven't read through ducatiz's oil filter thread yet. The only filters to stay away from are the Frams.
I use a cheap pair of HF oil filter pliers to get the filters off, and a wide rubber band around the filter to tighten them by hand. Using a torque wrench on a spin-on oil filter is silly.
It's OK to use both hands for that. Never had a leak.
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
Quote from: bergdoerfer on May 05, 2011, 11:59:47 AM
Just to be clear:  the K&N are made by HiFlo, but the element is different.  It could just be dyed red, which is my feeling, but the filters are identical save for the label, the K&N nut, and the color of the element.  I believe the elements are the same size and material from what I can see with the naked eye ( and I seem to remembe they weighed within 0.05 oz of each other...)
I don't torque them, but I use a strap wrench off and on.
I've never used a tool to put a filter on in my life.
I do wear mechanic gloves which have rubber on the fingers and that probably allows me to turn the filter easier.
Dirty oil on the o-ring.  Once its finger tight, give it another 1/2 to 3/4th turn.   Also recheck after you go riding and it's cooled down.  If its going to loosen, it will be too easy to turn at that point.
And you can pick up a cheapo channel-lock at a 99 cent store.  I bought mine at Jacks 99 Cent store in Manhattan.  Keep it sprayed with WD40 and it never rusted.
Every time I've tried on my Monster it leaks.
I don't care if I have to weld the thing on...
I don't want it to leak.
